EAGLE User Chat (English) Use of Eagle for RF microstrip
  • Views 660 views
I have a friend who is struggling with Eagle and I'm afraid my
experience does not cover his problem.  He needs to lay out a microwave
amplifier circuit which will consist of the usual components
(transistors, resistors, caps) plus some microstrip patterns.
Anyone on the list using Eagle for this purpose?  If so, I'd appreciate
hearing how you handle the microstrip -- have you made a library of
various dimensioned "devices" and then make a schematic using those
parts, and eventually a board layout?  He says this is not practical and
is just using the board layout editor to produce his designs.
Comments welcome.
Don
    microwave amplifier circuit which will consist of the usual components
    appreciate hearing how you handle the microstrip -- have you made a
    library of various dimensioned "devices" and then make a schematic
    using those parts, and eventually a board layout?  He says this is
    not practical and is just using the board layout editor to produce
    his designs.
    Comments welcome.
    No personal experience but its an Eagle/personal environment  problem.
    Search for 'microstrip' in the forums. I find that easiest at
    http://www.eaglecentral.ca/forums/
    The following ULP may of some use in the process
    ftp://ftp.cadsoft.de/eagle/userfiles/ulp/microstrip-radial-stub.zip
    What does you friend have to work with,? Is there a CAD diagram already with
    the microstrips sized. Like the example PDF you'll spot with the search.
    If so a dxf or image import may assist for some of the work.
    From that same search there are individuals whom you could contact for some
    guidance
    All the best
    Warren
    news.cadsoft.de
