EAGLE User Chat (English) New part creation?
  • Views 727 views
New part creation?
image Can anyone please tell me what I must have changed? I have been making new compoenets for my library and everything works and looks great, until I place the newly made components onto my schematic and the component is all filled in with the color Red. This just started happening so I know I must have changed something somewhere. I would like my components to be outlined in Red only.
Thanks in advance for your help. I am very appreciative.
Jeff
    Am 22.11.2011 04:34, schrieb Jeff Morrissey:
    Hey Joern,
    Just figured out what mysteriously got changed. Somehow I must have clicked on the layers tool, selected change and for some unknown reason clicked on fill style. Go figure. Anyway, problem solved. Thank you so much for being willing to help me out.
    Jeff
    Well done. I was not expecting your complete library but a small library
    with just that device.
    In future if you want to do just that or exchange library parts there
    are basically 2 ways to do that:
    1. Open a new library and leave it open.
    In control panel go to libraries, expand them, select the DEVICE you
    want, rightclick it with the mouse and select "copy to library".
    That is it.
    2. Drag and drop.
    A new library and the control panel both must be seen simultaneously on
    your sceeen. Just grab the device in control panel with your mouse, drag
    it to the library window and let go (drop).
    In any case you must name and save the new library.
    Joern Paschedag
    Jeff Morrissey wrote:
    Hey Joern,
    Thank you so much for being willing to help me out. Jeff
    Aahh! So that;s what you did.  You used a rectangle to create a box. If you
    inspect the libraries you will find boxes are made from wires on 4 sides.
    Changing the color fill style  for that layer  to get the same look will
    haunt you later on, I suspect.
    Warren
    news.cadsoft.de
    Hey Joern,
    Jeff
    Joern,
    Thanks for replying. I am using version 5.11.0
    As far as sending the library part, not sure how to. I can send a copy of my library via e-mail if I had your address.
    Just a note that might help solve the problem. When I create the part, it is displayed with a red outline only, which I am pretty sure that way it should be.
    Jeff
    Am 21.11.2011 02:22, schrieb Jeff Morrissey:
    Jeff
    Which version you use and can you send that library part?
    Joern Paschedag
