EAGLE User Chat (English) EAGLE parts on the Farnell site
  • Replies 12 replies
  • Subscribers 190 subscribers
  • Views 2253 views
I notice that a lot of the components on the Farnell website now have EAGLE library parts associated with them.
There are many that do not however.
I am always making EAGLE parts for components ordered from Farnell...is there a way to upload these so others may benefit too?
Dave
  • M0DCD
    M0DCD over 14 years ago in reply to M0DCD
    I've had a fix to this one, seems the instructions were wrong - it now works.
  • jealderson1
    jealderson1 over 14 years ago
    Hi all,
    I saw this thread on Monday and thought it was a great idea to share your library parts - I've asked around and if you send your parts to this address: CAD_Tech@element14.com then our global technology centre will be able to verify them and get them on our product pages.
    You can also upload libraries to share with other CadSoft users here:
    http://www.cadsoftusa.com/downloads/libraries?language=en
    Hope this helps!
    Joe Alderson - Farnell element14 Technical Marketing Engineer
  • M0DCD
    M0DCD over 14 years ago in reply to e14 Contributor
    Tried that but the library file refuses to do anything - I get an error report.
    Loading C:/Program Files/EAGLE-6.2.0/lbr/ADI-AD797ARZ.lbr ...
    Error:
    line 1, column 1: Start tag expected.
    I think this one's a dud myself.
    e14 Contributor over 14 years ago in reply to M0DCD
    Am 18.05.2012 12:54, schrieb M0DCD:
    These Eagle files - they're scripts but do you need to be using Ultra Librarian to actually use them? They don't translate as scripts in Eagle themsleves and throw up errors if you try to run them. If they are Ultra Librarian files, would it be less confusing to label them as such?
    These script files can easily be imported into a new or existing
    library. Just open/generate a library and go Data /execute script
    and point the way to "nameofthescript.scr".
    Joern Paschedag
  • M0DCD
    The devices are created by Ultra Librarian,  they have a lot of devices already created.  Have you looked there?
    Jorge Garcia wrote:
    On 12/17/2011 9:41 AM, Dave Bullock M.B.E. wrote:
    >> Hi,
    >> Thanks
    >> Dave
    Hi Dave,
    This is an initiative by Farnell, they are generating these library
    components for EAGLE. If my brain is working correctly I believe they
    mentioned that they have something like 29000 components in their
    catalog associated with EAGLE libraries.
    In the coming year they expect to add more.
    One call is probably just leaching off the Farnell website.
    onecall is a division of Premier Farnell UK Limited
    news.cadsoft.de
    Dave
    Hi Dave,
    This is as much as I know.
    hth,
    Jorge Garcia
    Cadsoft Support
  • e14news
    e14news over 14 years ago
    Hi Mike,
    I find it hard to believe that manufacturers would go to the trouble of
    generating EAGLE parts for their components considering all the variety
    of CAD software out there.
    Yet as you search for semis on the Onecall site there are what seem to
    be clickable icons marked (CAD CadSoft_EAGLE (2.35KB) EN
    <http://www.farnell.com/cad/1466491.zip>)
    For example:-
    http://onecall.farnell.com/texas-instruments/tle2426cd/virtual-ground-reference-smd-2426/dp/8454809
    I thought Farnell and Cadsoft were in a symbiotic relationship..... so
    who is adding these icons to the Onecall website?
    Dave
  • e14news
    Aaah, sorry, I misunderstood.
    I don't know of any way to do that, I presume they're generated by manufacturers rather than users.
    They tend to use scripts to generate library parts rather than give the library parts directly, which takes more effort to do but ensures future compatibility.
    Is there anyone from Farnell reading this that is able to comment?
