EAGLE User Chat (English) Drop button :-(
  • Subscribers 189 subscribers
  • Views 1497 views
Drop button :-(
Inside the add componentt menu, WHAT IN THE HECK WERE YOU THINKING WHEN YOU PUT THE DROP BUTTON THERE?  First of all, any normal user who's not completly high on bath salts would think "drop" would drop the component onto the schematic. BUT NO, it drops a subset of the library from the database obviously.  I mean "remove" takes a few too many characters to fit in the button nicely or something.  Then it corrupts the library so when I "use" the library again, I get an error message and can't use those components any more.
  • Dusan_R
    Dusan_R over 14 years ago in reply to e14 Contributor
    Hi Richard,
    I don't have any problem wit that button, but what annoys me much is the fact, that the munh more usefull button, USE, is missing.  I remember it was in early versions (2.x, perhaps 3.x) and then it disappeared. I hoped in 6.0 it would appear, but it didn't - pity...
    Op Wed, 21 Dec 2011 11:38:43 +0100 schreef joseph taft
    <noreply-80287@element14.com>:
    Well, it's just one of those little Cadsoft things: you spent 10 years
    trying to avoid clicking on that button by accident, while during that
    entire period you've got no idea whatsoever what it is doing there or why
    it is named that way.
    It adds to the nerdy charm of the program, I guess..
    Maybe, when Klaus has fully recovered from working on the 'CUT & COPY'
    soap, he can take on this one?
    Richard
    brett and joesph are right the word "DROP" on that dialog should be if anything drop component to schematic...
    there shouldnt be ANY option to DROP a lib in that dialog...
    a new dialog should be made for ADDING and DROPPING libraries
    (the way its down now is bad anyway, with a file open dialog)
    unitutive
    that dialog is for ADDING parts to sheet
    my 2 cents
    Drop? That is one of the most UN-intuitive features of Eagle. Somebody might
    think that it would drop the listed component into the schematic, but no
    that's not what happens at all.
    Just try to drop that component into your project and see what happens. It's
    very funny.
    "Richard Hammerl" <support@cadsoft.de> wrote in message
    news:jcslat$p5p$1@cheetah.cadsoft.de...
    Drop means that the library file will be dropped from the list
    of libraries in the dialog. Nothing happens to the library file
    itself if you "drop" it. It is not deleted, nor is it saved.
    It is no longer in use or better said not available forthe ADD
    command. That's it. It does not corrupt the library.
    I don't know what happened with your library..... You could send it
    to me, then we can try to get out.
    Richard Hammerl
    Am 21.12.2011 14:01, schrieb Richard Hammerl:
    Yes. It DOES mean that. Expert users know that. But for NEW users, the
    word DROP means something completely different, and it's quite
    definitely NOT the intuitive word to use for THAT function. EAGLE is
    full of strange anachronistic words that either don't mean a thing at
    all, or even mean a completely DIFFERENT thing (e.g., the command WIRE
    should NOT be used for wiring components - aaargh!).
    When brushing up EAGLE's GUI, CadSoft should use better words for things
    - you see that users can get quite frustrated in their work due to bad
    wording...
    See also my post 'EAGLE GUI (2): Unintelligible menus' in
    'eagle.suggest.eng', which is not only valid for menus, but also for
    dialogs etc.
    Andreas Weidner
    Richard Hammerl
