EAGLE User Chat (English) Copy Group + Create Board = Connections where none should be
  • Views 215 views
Hello i am new to eagle, and have a problem.
I made a new project, made a circuit and because i needed 1 part of it 6 times, i grouped and copied this part and deleted the additional wires after.
As i let Eagle create the board from the circuit and started with positioning i recognized that some resistors are conneted to resistors from the copied Group where the similar part of this group is placed.
May someone can help me what may whent wrong?
    Ok problem solved...
    it was just that any wire needed to delete and draw again and delete again and draw again ... until the line is right, also when nothing realy changes in the circuit image... unfortunitly the program crashes later when trying to safe 2 hours work... what was for me the end of the usage periode, i will watch aout for a different programm that may not need 20 times the same work and crashes when trying to safe image.
