EAGLE User Chat (English) Cut Tool Missing From 6.1.0 Libary???
  • Views 995 views
Hi Everyone,
I am trying to copy the elements of a package into a new package and modify. But the cut tool in Eagle 5.x Library editor is missing form the 6.1.0 library editor. Did the paradigm change or am I missing something?
Joe
    Richard,
    Thanks! I was able to get it to work with your help. I think I will keep EAGLE configured the way it is. Definitely makes more sense, teaching the cut command was always an inssue for new users.
    Joe
    Op Sun, 19 Feb 2012 20:51:57 +0100 schreef joe Baumbach
    <noreply-85304@element14.com>:
    You're missing something...
    from the 6.0 release notes:
    • COPY command:
    - In older versions of EAGLE the COPY command was used solely to copy
    objects
    within a drawing, as opposed to the Windows behavior, where COPY places a
    copy of the selected objects (i.e. the GROUP) into the system's clipboard.
    As of version 6, EAGLE's COPY command primarily behaves the same way as in
    other Windows applications, by putting a copy of the current group into the
    clipboard. The original functionality of copying selected objects, or
    copying library objects between libraries, is still fully available, which
    is especially important to keep existing scripts and ULPs working.
    What has also often irritated Windows users is that in EAGLE the CUT
    command has only copied the current group to the clipboard, but did not
    actually delete the group from the drawing. Since a CUT command that
    deletes the group would not be of much use in a board/schematic pair that
    is connected via forward-&backannotation, the CUT command has been
    removed from the main pulldown menu and the command button toolbar. It is
    still fully available from the command line or within scripts. The command
    SET Cmd.Copy.ClassicEagleMode 1
    restores the old behavior of both the COPY and the CUT command. Note that
    this setting only takes effect the next time you open an editor window.
    - Added a note to the online help of COPY about how to copy objects from
    one schematic sheet to an other.
    HTH
    Richard
