EAGLE User Chat (English) USB traces
  • Subscribers 189 subscribers
  • Views 540 views
USB traces
This is not an Eagle-specific question, but I need to do a short run
of traces between two USB connectors on a board, connecting a USB host
with a USB slave.  I have never laid out USB signals before and I am a
little nervous about how to do it.  Must I treat the data lines as RF
transmission lines? What trace width and spacing should I use? Can I
use vias? What trace thickness should I use?  The traces joining the
two recepticals are only going to be about 2 inches long.  How
critical is USB layout anyway?
Robert Scott
Ypsilanti, Michigan
    e14 Contributor over 14 years ago in reply to amigabill
    On Tue, 06 Mar 2012 14:26:42 -0500, Bill Toner <amigabill@gmail.com>
    wrote:
    >If you're USB2 speeds, then soem care should be taken. I don't know
    >about USB1 speeds.
    >As it sounds like you are doing a connector/board/connector thing, I
    >will assume you are not going to be within the rise time distance that
    >lets you ignore impedance matching, and that you will have to pay
    >attention to that.
    >Some USB2 layout guides I found on the google:
    >http://www.ti.com/lit/an/spraar7/spraar7.pdf
    >http://www.usb.org/developers/docs/hs_usb_pdg_r1_0.pdf
    >http://www.atmel.com/Images/doc7633.pdf
    These documents are exactly what I needed.  Thanks for the pointers.
    Robert Scott
    Ypsilanti, Michigan
  • amigabill
    amigabill over 14 years ago
    about USB1 speeds.
    attention to that.
    These are likely to talk about driver to connector type things more than
    connector direct to connector things. Figure out your target impedance
    and work to that. Figure out what trace width/space is easy to
    manufacturer from your board peeps, and choose a width/space/height from
    plane combination to suite the impedance needs.
    billt
    Robert Scott
    Ypsilanti, Michigan
