EAGLE User Chat (English) ULP for computing distance between components
  • Views 525 views
Hi, I would like to know if there is a ULP that calculates the distance
between two adjacent components. More specifically, from edge(cmp 1) to
edge(cmp 2).
I am in the middle of somethign and have little time to search the ulp
list, although I did search here on the forums a bit for "distance ulp".
Did not find anything of relevance.
Thank you all in advance,
OW
    http://www.cadsoftusa.com/cadsoft-downloads/file/measureslength
    distance between two adjacent components. More specifically, from
    edge(cmp 1) to edge(cmp 2).
    ulp". Did not find anything of relevance.
    Version 6 has a dimension feature that may work for you if you are using v6.
    Version 5 had no such feature. Most use the MARK command and simply read off
    the polar distance.
    A ULP would be of little use as the edges of a package are not normally
    defined as such. Information in the tPlace or document layers are often
    larger and sometimes smaller
    I guess your own libraries could be made exactly.
    Then there's the issue of the direction of measurement.
    Not the answer you were after, no doubt.
    Warren
    news.cadsoft.de
