EAGLE User Chat (English) Difference between RCL.lbr and Resistor.lbr?
  • Subscribers 189 subscribers
  • Views 1406 views
After switching back and forth between the RCL and Resistor libraries I cant seem to see a diference. Is there any differences between the two different libraries? The reason I ask is that one of our board assembly house called and said the 0402 capacitor pads were wrong and they were getting lots of tombstoning of the parts. My co-worker wants to edit the library to just correct the pads instead of switching everthing over to the C0402K package. If we edit the library and then push it out to all the engineers do we need to edit both RCL and Resistor or just one and ignore the other? Crazy I know but he is the senior and it would be easier then going through every single part on that board and changing all of them.
    Am 02.05.2012 00:47, schrieb Bill Martin:
    On 04/30/2012 05:35 PM, Nate Chapman wrote:
    >> If I remember correctly there really is no difference in the 2 libraries.
    If this is from V6.x, it's easy to tell for sure. Do a file diff of the
    XML files for the two different libraries. It may still take some visual
    inspection, due to possible formatting differences in the text, but may
    be worth a try.
    Bill
    Both libraries, rcl- and resistor.lbr exist since version 5 already.
    There must be a difference because there is quite a difference in the
    file size. AFAIK a lot of packages have been thrown out.
    Anyway I think a stupid name has been chosen for the resitor library.
    You want some inductors or capacitors?? Look at the resistor.lbr image
    Joern Paschedag
    e14 Contributor over 14 years ago in reply to Nate1616
    be worth a try.
    Bill
  • Nate1616
    Nate1616 over 14 years ago in reply to e14 Contributor
    That would be easy but I think we might have used them interchangeably. Some guys use Resistor other RCL. I was just wondering if there was any difference so that we could standardize on one library or the other.
  • Nate1616
    I would say edit the .ldr file that you are pulling the  pieces from.  If you have them pulling from multiple libraries then you have to change both.
