EAGLE User Chat (English) ULP script dlgAccept()
  • Replies 8 replies
  • Subscribers 190 subscribers
  • Views 1152 views
ameliaamelia
ameliaamelia over 14 years ago
In the following variable length dialog
int XXX;
int YYY;
XXX = dlgDialog ("Menu"{
for (YYY = 1; YYY < 5; YYY++)
  dlgCell .... dlgAccept(YYY);
YYY contains always 5.
It seams that dlgAccept "accepts" only constants value such as 1, 2, 3 ....not a variable, or I'm wrong?
EAGLE HELP:
void dlgAccept([ int Result ]);
amelia
  • ameliaamelia
    ameliaamelia over 14 years ago in reply to e14 Contributor
    To Warren,
    You are right, see my last analisys on http://www.element14.com/community/message/52947#52947/l/url-dlgaccept
    Amelia
    e14 Contributor over 14 years ago in reply to dukepro
    Chuck Huber wrote:
    Amelia,
    Your problem demonstrates that the argument is passed by reference,
    that is, a pointer to the integer value is what is actually passed.
    The argument to dlgAccept() is passed by reference, not by value.  ULP
    is somewhat object oriented in that an int is always a reference to an
    integer object, much like a Java Integer.
    In the first scenario (direct definition), each constant value is
    promoted to an integer object and is given a value that can not be
    changed, and a reference to that object is passed to dlgAccept().
    Thus, any changes to the value of what's at the pointer, also changes
    the value that dlgAccept() uses as a return value.
    Contrast this to a procedural language, like C, where integers are
    passed by value.  i.e. a copy of the value is given to the called
    function, which can then manipulate the value without interfering with
    the value of the original integer.  Also, changes to the original
    integer do not affect the value that was passed to the called
    function.
    One work around would be to initialize an array of integers with each
    of the value return values, just like what you have done with the
    selects[] string array.  Then pass each of these as argument to
    dlgAccept().
    string selects[] =
    "Text1",
    "Text2",
    "Text3",
    "Text4",
    "Text5",
    "Text6",
    "Text7",
    "Text8",
    "Text9"
    int selectNums[] = { 1,2,3,4,5,6,7,8,9 };
    int select_num;
    for (select_num = 0; select_num < MAX_TEXT; select_num++)
    dlgPushButton(selects[select_num]) dlgAccept(selectNums[select_num]);
    Hope this helps,
        - Chuck
    Chuck's suggested work around does not solve the problem for the same
    reasons as Amelia's.
    The result is the same. (v4.16)(v5.12)
    The UL does not appear to resolve variables in the statement code of the
    dlgPushButton, and holds the variable in tact so the present value of
    "select_num" is used when the statement runs. As I see it you cannot
    determine which button has been clicked. I would like to see the technique
    that shows me I'm wrong.
    dlgListView or dlgLIstBox  is likely a better approach than a large number
    of buttons created in a loop.
    Would Alf or Walter please comment?
    Warren
    news.cadsoft.de
  • dukepro
    dukepro over 14 years ago in reply to e14 Contributor
    Amelia,
    Your problem demonstrates that the argument is passed by reference, that
    changed, and a reference to that object is passed to dlgAccept().  Thus,
    any changes to the value of what's at the pointer, also changes the
    integer do not affect the value that was passed to the called function.
    One work around would be to initialize an array of integers with each of
    the value return values, just like what you have done with the selects[]
    string array.  Then pass each of these as argument to dlgAccept().
    string selects[] =
         "Text1",
         "Text2",
         "Text3",
         "Text4",
         "Text5",
         "Text6",
         "Text7",
         "Text8",
         "Text9"
    int select_num;
    Hope this helps,
        - Chuck
    ameliaamelia wrote:
    Again, two complete examples:
    >> ///////////////////////////////// 1- direct definition with constant
    int select_dlg;
    >>   | select_dlg = dlgDialog("XXXX") |
    >>   | dlgGridLayout |
    >>   | dlgCell(0,0) dlgLabel(E.name); |
    >>   | dlgCell(0,1) dlgLabel(E.value); |
    >>   | dlgCell(0,2) dlgLabel(E.package.name); |
    >>   | dlgCell(1,0,1,2) dlgPushButton("Text1") dlgAccept(0); |
    >>   | dlgCell(2,0,2,2) dlgPushButton("Text2") dlgAccept(1); |
    >>   | dlgCell(3,0,3,2) dlgPushButton("Text3") dlgAccept(2); |
    >>   | dlgCell(4,0,4,2) dlgPushButton("Text4") dlgAccept(3); |
    >>   | dlgCell(5,0,5,2) dlgPushButton("Text5") dlgAccept(4); |
    >>   | dlgCell(6,0,6,2) dlgPushButton("Text6") dlgAccept(5); |
    >>   | dlgCell(6,0,6,2) dlgPushButton("Text7") dlgAccept(6); |
    >>   | dlgCell(6,0,6,2) dlgPushButton("Text8") dlgAccept(7); |
    >>   | dlgCell(7,0,7,2) dlgPushButton("+Text9") dlgAccept(8); |
    ///////////////////////////////// 2- using a loop with variable
    /////////////////////// int MAX_TEXT = 9;
    string selects[] =
    >>   | "Text1", |
    >>   | "Text2", |
    >>   | "Text3", |
    >>   | "Text4", |
    >>   | "Text5", |
    >>   | "Text6", |
    >>   | "Text7", |
    >>   | "Text8", |
    >>   | "Text9" |
    int select_dlg;
    int select_num;
    >>   | dlgGridLayout |
    >>   | for (select_num = 0; select_num < MAX_TEXT; select_num++) |
    >>   | if ( select_num == 8) |
    >>   | dlgCell(select_ele_num,0,select_ele_num,2)|
    >>   dlgPushButton(""selects[select_num]) dlgAccept(select_num);  | |
    >>   } | | else |
    >>   | dlgCell(select_ele_num,0,select_ele_num,2)|   |
    >>   dlgPushButton(selects[select_num]) dlgAccept(select_num);  | | } |
    The first works OK, the second NO, it returns always 8.
    Amelia.
    You are correct (I get it always returning a 9)  but I can see that is not
    what you want.
    Each of your buttons is built with the statement containing
    dlgAccept(select_num); The variable isn't resolved as the button statement
    is stored but rather the statement is stored verbatum to run later as the
    variable name "select_num". So it always returns its current value no matter
    which button is clicked.
    Maybe someone has coded around this limitation  before and can offer a
    solution.
    Warren
    news.cadsoft.de
    ///////////////////////////////// 1- direct definition with constant //////////////////
    int select_dlg;
    dlgGridLayout
    ///////////////////////////////// 2- using a loop with variable ///////////////////////
    int MAX_TEXT = 9;
    string selects[] =
    "Text1",
    "Text2",
    "Text3",
    "Text4",
    "Text5",
    "Text6",
    "Text7",
    "Text8",
    "Text9"
    int select_dlg;
    int select_num;
    dlgGridLayout
    else
    Amelia.
    e14 Contributor over 14 years ago in reply to ameliaamelia
    ameliaamelia wrote:
    Yes, if you use a single statement, but try using the loop as in my
    example or :
    int YYY;
    YYY = 1;
    YYY = 2;
    The returned Accept() value is always the last specified on the
    variable, in the upper example = 2.
    Amelia.
    OK you accept variables can be used and not just constants as you initially
    queried.
    So your new need for understanding is "why does the returned value == 2 when
    I wish to close and exit the dialog at the point when YYY==1"?
    As per the HELP the code after the dlgAccept() is run. So YYY is changing to
    2 before the Dialog closes so will always be 2.
    Structure / bracket your code to prevent this effect.
    If you are still having a problem. provide some real code so you can be
    shown where you are going wrong, if thats the case.
    HTH
    Warren
    news.cadsoft.de
  • ameliaamelia
    Yes, if you use a single statement, but try using the loop as in my example or :
    int YYY;
    YYY = 1;
    YYY = 2;
    The returned Accept() value is always the last specified on the variable, in the upper example = 2.
    Amelia.
    int XXX;
    int YYY;
    for (YYY = 1; YYY < 5; YYY)
    + dlgCell .... dlgAccept(YYY);+
    +EAGLE HELP: +
    void dlgAccept();
    amelia
    Using v5.12, dlgAccept() does accept a variable. The ULP below displays a
    MessageBox result of 66 from the MYexit variable.
    HTH
    Warren
    int acceptexit = 66;
    int MYexit;
    string result;
    MYexit = dlgDialog("Accept-Test"){
            dlgPushButton("+OK"){
             dlgAccept(acceptexit);
            dlgPushButton("-Cancel"){
             dlgReject();
    sprintf(result,"%u",MYexit);
    dlgMessageBox(result);
    news.cadsoft.de
