EAGLE User Chat (English) gbr274x6 help?
  • Views 261 views
gbr274x6 help?
I'm using gbr274x6 and it converts the gerber file into a .scr file but it does not convert it in to a .whl file. Does anyone know how to get the .whl file?
    Hi Bob,
    The gerb274x standard got rid of the need for a wheel, that's why it has
    pretty much replaced and obsoleted the older gerb274D. The idea of the
    tool is to convert a set gerbers into a script file which can be
    imported into EAGLE.
    Once imported into EAGLE if you really needed the wheel file for
    whatever reason then you can simply export the gerbers again using the
    appropriate cam job.
    hth,
    Jorge Garcia
