EAGLE User Chat (English) help needed - Improving ULP "Array_Board_V52"
  • Subscribers 189 subscribers
  • Views 576 views
Hello All,
today I noticed the often used ULP "Array_Board_V52" has a minor
drawback: polygons that contain curves (and not only straight lines)
have the curves replaced with simple lines.
Link: http://www.cadsoft.de/downloads/file/array_board_v52.zip
This is because the "@radius" or "curve" parameter is stripped or not
printed to the intermediate script.
Reading the source I found this at lines 192ff:
               s.polygons(p) {
                  wid=p.width/GridDivisor;
                  isol=p.isolate/GridDivisor;
                  printf("change layer %d;\n",p.layer);
                  printf("change isolate %f;\n",isol);
                  printf("change rank %d;\n",p.rank);
                  printf("change thermals %s;\n",onoff[p.thermals]);
                  printf("change orphans %s;\n",onoff[p.orphans]);
                  printf("change pour %s;\n",pour[p.pour]);
                  if(cmn==0) printf("polygon %s%s%d%d %f",s.name,suffix,i,j,wid);
                  else printf("polygon %s %f",s.name,wid);
                  p.wires(w){
                     xx1= w.x1/GridDivisor+dx;
                     yy1= w.y1/GridDivisor+dy;
                     xx2= w.x2/GridDivisor+dx;
                     yy2= w.y2/GridDivisor+dy;
                     printf(" (%f %f)",xx1,yy1);
                  printf(" (%f %f);\n",xx2,yy2);
starting at  "p.wires(w){...}" is the problem in my opinion. There is
nothing that detects and prints out the @radius or curve parameters.
As I did not understand the internal data structure accessed here I was
not able to fix that. It looks like there needs to be an if-statement
checking if the current polygon segment is a line or a curve and
printing the radius if required.
Could anybody please give a hint? Unfortunately no clue where to start.
Any help really appreciated. Thanks, best regards.
Stefan Langer
    e14 Contributor over 14 years ago in reply to Morosh
    Thanks to Maurice we now have an improved ULP available.
    Please ignore the one from maurice's last post.
    Changes: proper handling of arcs in signal polygons.
    Attached: Array_Board_V53.ulp (Date: 25.07.2012)
    Creator: Maurice SAAB (usenet user name)
  • Morosh
    Morosh over 14 years ago in reply to e14 Contributor
    On 18/07/2012 18:09, Stefan Langer wrote:
    Am 17.07.2012 07:21, schrieb Maurice SAAB:
    >> I'll have a look, and update ASAP.
    Maurice, thanks in advance - free drink for you if we ever meet image
    If you don't have the time to fix it but know the trick and tell us -
    even that is great.
    Regards, Stefan
    here is the new version, could you give it a try
    Regards
    Maurice
    array_board_v53.ulp.zip
    even that is great.
    Regards, Stefan
  • Morosh
    On 16/07/2012 16:05, Stefan Langer wrote:
    Hello All,
    >>                 s.polygons(p) {
    >>                    p.wires(w){
    Stefan Langer
    Regards
