EAGLE User Chat (English) No components visible in the add menu. (freeware version)
  • Views 480 views
    Jorge Garcia wrote on Thu, 19 July 2012 10:12
    On 7/19/2012 6:57 AM, Marco Prata wrote:
    Hi
    Just starting up with eagle.
    I've tried to follow the tutorials but i have hit a snag.
    When i press the add button in a schematic no components show up.
    In the control pannel the directories for the libraries look good.
    I have even managed to add the sparkfun libraries, and they do show up
    under libraries.
    But still nothing show ups when i press add.
    Any help?
    Regards
    Hi Marco,
    The libraries are inactive, to put them in EAGLE's active search list
    type:
    USE * <press enter key>
    When you click add the libraries should show up. If you have the
    sparkfun library saved outside of the lbr folder then you'll have to
    put
    it into use using the Library-> Use... pull down menu.
    It's a bit more complicated than that.  In Control
    Panel->Options->Directories there is a path that EAGLE uses to search for
    libraries.  The "use *" command will look through these directories in
    order.  If you have happened to change that entry then "use *" will only
    find what is in the directories that are specified.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Hi
    In the control pannel the directories for the libraries look good. I have even managed to add the sparkfun libraries, and they do show up under libraries.
    Any help?
    Regards
    Hi Marco,
    The libraries are inactive, to put them in EAGLE's active search list type:
    USE *
    sparkfun library saved outside of the lbr folder then you'll have to put
    hth,
    Jorge Garcia
