EAGLE User Chat (English) CAM job to print
  • Views 398 views
  • eagle
  • job
  • cam
CAM job to print
Is it possible to use a CAM job to print to an HP Deskjet 2060 printer?
  • techsupport
    techsupport over 14 years ago
    The CAM Processor can not be used to drive a printer.  In earlier version of EAGLE it was possible to define the port that was going to be used.  In the latest versions of EAGLE the CAM Processor is used to generate files.  I did not notice any drivers in the CAM Processor to produce a DeskJet 2060 output, but it doesn't mean that you can't use a compatible driver. The printer drivers used by the CAM Processor are defined in the EAGLE.def file.  Not sure if you have a need to make one, but thought it would be a good idea to point it out.
    I hope this helps.
    Best Regards,
    Ed
