EAGLE User Chat (English) polar grid - too strange suggestion?
  • Views 466 views
Hello friends of Eagle,
lately I realized that I have more and more circular boards. Very often
one runs into trouble placing components on circular positions. I know,
scripting is ONE solution here.
But I wonder if there could ever be a circular grid option in eagle.
Would be helpful for a number of applications... IMHO.
For instance with specifying a constant offset for radii and number of
angular sections on the first radius. On increasing radii the angular
sections could be halved as soon as the arc length is >= double of the
initial arc length. This would give a angular grid defined by two values
which keeps nearly constant density...
See attached image for illustration. Sorry, rough quality.
Any thoughts? Worth a feature request?
Regards, Stefan
PS: is there an ULP anywhere helping with angular placement? Haven't
found anything...
    Am 20.08.2012 15:09, schrieb Andreas Weidner:
    Am 15.08.2012 23:20, schrieb Stefan Langer:
    >> found anything...
    EAGLE does NOT have any polar grid, but positions CAN be entered with
    polar coordinates in the command line. With the syntax
      (pR A)
    you can access the point with the radius R and the angle A. E.g.,
      wire (p1 90) (p2 180);
    draws a line from (0,1) to (-2,0) in cartesian coordinates.
    Great. Thanks. Somehow overlooked that. Regards, Stefan
    found anything...
       (pR A)
    See also the help text for coordinate entry.
    Andreas Weidner
