EAGLE User Chat (English) Quality of Eagle schematics for publication
  • Subscribers 189 subscribers
  • Views 753 views
Our firm is shopping a new CAD suite for both PC layout and schematic capture.  It seems that many of the high-priced, "professional" packages utilize the schematic utility solely as a means of generating a netlist for board layout, the 'publication quality' of the schematic remaining utilitarian at best.  Can Eagle generate a decent-looking schematic that can be imported into a product manual or serve for a magazine article, etc.  As a benchmark for schematic quality, I have attached a PDF of our current program's output.  I hesitate to name the program, but it is probably 20 years old, the company is no longer in business, but it was absurdly inexpensive and only now needs to be replaced.  I'd be very appreciative of any direction that contributors of this Forum might lead me to meeting this objective.
imageExample.pdf
    I agree with Tilmann: see the attached low resolution example.
    Regards
    Alberto Vignati
    Il 02/10/2012 08:39, Tilmann Reh ha scritto:
    Larry Baxter schrieb:
    >> See attached, partial, not polished for publication.  I draw my own
    >> symbols when the supplied versions look too ugly; for publication I'd
    >> want to redraw a few more.
    In the schematic you should not use the (ugly) vector font, but
    "proportional" instead. This makes the document much prettier - and
    searchable (if you export/import it the right way).
    For "classic" documentation, don't use colored schematics - use the
    "black only" checkbox in the print dialog or the "monochrome" checkbox
    in the export image dialog.
    >> Export Image accepts 1000 dpi, attached is 450 so it isn't too big for
    >> the mailbox...
    If you want to get good (and not bloated) documents, try to use a
    vectored format like PS/EPS instead of a pixel based image file - you
    get much higher quality at less space, and a searchable result (if your
    document processing software is able to import such a format - otherwise
    high resolution PNG is OK).
    Tilmann
    the mailbox...
    Tilmann
    BTW, you can use 3-pole Sallen+Key lowpass and save an op amp, R74 not
    needed, Q4+Q6 should be CMOS switches, add zap diodes to the
    outputs...can't resist design reviews...
    ...L
    the mailbox...
    ...L
    e14 Contributor over 13 years ago in reply to fritzz
    d r schrieb:
    Look at items on Sparkfun.com
    They often have an Eagle schematic, so you can be the judge.
    http://dlnmh9ip6v2uc.cloudfront.net/datasheets/BreakoutBoards/VS10XX-v15.pdf
    This is an explicitly bad example.
    To the OP: yes, with EAGLE you can generate perfectly looking schematic
    drawings.
    Tilmann
  • fritzz
    fritzz over 13 years ago
