EAGLE User Chat (English) Using eagle3d inc files in test mode
  • Views 614 views
This is something that I cant get working.
Maybe I am following a wrong approach.
If I render this simple piece of code always the 100n component is rendered
whatever I use in the the declare.
#declare inc_testmode = on;
union{
#ifndef(inc_testmode)
        object {CAP_DIS_WIMA_25_025_046_075("10n",)}
#else
        object {CAP_DIS_WIMA_25_025_046_075("100n",)}
#end
Why is this so be course I cant find anything in de doc.
    In article <k65pmo$92r$1@cheetah.cadsoft.de>, info@oldtimetech.nl
    says...
    It doesn?t matter if I declare inc_testmode, always the else statement is
    executed.
    maybe I should remove all de ifdefs and replace them by simple if
    statements.
    You dont normally want to just swap #ifdef's with #if's because they
    mean different things (if you understand that then by all means do of
    course)
    I havnt used POVray for around 20 years so I'm not sure of the correct
    syntax you can use.
    There should be a .chm file though -
    My guess is this is a simple case of the token being defined in an
    include somewhere (the "= on" is irrelevant to the #ifndef)
    change it to
    #declare mytoken;
    #ifndef (mytoken)
       do(10)
    #else
      do(100)
    #endif
    or whatever the correct sytax is - and swap it to see if it changes
    if it does - you have a duplicate  - probably in an include file
    if those are in scope in povray now
    It doesn’t matter if I declare inc_testmode, always the else statement is
    executed.
    maybe I should remove all de ifdef;s and replace them by simple if
    statements.
    "fred"  schreef in bericht
    news:MPG.2aee1b533f6acc07989692@news.virginmedia.com...
    In article <k5uumq$a9u$1@cheetah.cadsoft.de>, info@oldtimetech.nl
    says...
    rendered
    I'm not familiar yet with ULP but standard practice for preprocessor
    directives say that ifdef ifndef etc will be true if the label is
    defined (ie thats what its there for)
    i.e. ifndef does not relate to a value - just the existance of the label
    You should find this to be the case in any language.
    says...
