EAGLE User Chat (English) Electronic Component Zero Orientation For CAD Library Construction
  • Views 936 views
We see very little mention of getting the orientation correct when building
library packages.
IPC has some rules
http://pcbget.ru/Files/Standarts/IPC_7351.pdf
This similar document results from those rules and depicts how they should
look in the your library (zero degrees)
http://ohm.bu.edu/~pbohn/__Engineering_Reference/pcb_layout/pcbmatrix/Component%20Zero%20Orientations%20for%20CAD%20Libraries.pdf
Getting these consistent and correct in your libraries can assist your
assembler when they review your design and setup the machines to assemble
your boards. This should result in less errors, cost and improve
turn-around.
I hope this assists you
Warren
news.cadsoft.de
    e14 Contributor over 10 years ago in reply to e14 Contributor
    Electronic components distributor http://www.components2world.com, offer all parts for your need.
    >library packages.
    >IPC has some rules
    Several organizations made such rules/recommendations. They change
    them from time to time to keep us busy.
    EIA 481, IPC-7351, IEC 61188-7, each in various editions.
    FED made http://wiki.fed.de/images/0/0e/Lage_der_Bauteile.pdf
    http://blogs.mentor.com/tom-hausherr/blog/tag/ipc-standards/ describes
    the madness.
    CadSoft libraries were not even consistent.
    Oliver
    Oliver Betz, Munich
    despammed.com is broken, use Reply-To:
