EAGLE User Chat (English) hide a net?
  • Views 303 views
hide a net?
I know I can SHO to highlight, but is there a way to hide all routed nets except fot VCC and GND?
    Would you like the question answered here or in the eagle.support.eng forum?
    Double posting is not good etiquette.
    I don't  believe there is currently a way to get what you ask. Once a trace
    is routed into copper turning off the layer or highlighting with 'show' is
    about all you can do.
    Have a look at ripup and ratsnest. This could be an approch for  you earlier
    in the routing process particularly the command
    ratsnest ! GND VCC
    That will hide all the GND and VCC airwires which often get attached to a
    polygon later so you get them out of the way while routing the other
    signals.
    HTH
    Warren
    news.cadsoft.de
