EAGLE User Chat (English) version 6.4 LTspice schematic importing into EAGLE
  • Subscribers 189 subscribers
  • Views 1493 views
I've just been reading the release notes on EAGLE 6.4 and read you can import LTspice Schematics into EAGLE.
This is great, as I tend to use LTspice alot for simulating circuits.
However, when i try to impotr the .asc LTSpice schematic file I get an error window pop-up:
Eagle: import-accel.ulp
Wrong file signature: Version
<pressed ok>
Followed by:
Error:
Can't find ' <insert directory here>\<LTspice schematic name>.scr'
which to me sound like your supposed to export something from LTSpice, which spits out a script file to run in EAGLE.
Can't find anything in LTspice that does this so am a bit stumped.
Can anyone help?
    autodeskguest over 9 years ago in reply to joshuaiwhite1
    On 1/23/2017 11:21 AM, Joshua White wrote:
    I'm getting the same errors as Tronicus:
    <pressed ok>
    Followed by:
    Error:
    Any help?!
    -JW
    https://www.element14.com/community/message/213933
    Hello Joshua,
    I hope you're doing well. You are using the wrong ULP, you need to use
    the LTSpice ulp, it has an icon in the top right where you can import
    your LTSpice schematic from.
    Currently this feature is Windows only although some work has been done
    to port it over to Linux and Mac. This work is still ongoing.
    Best Regards,
    Jorge Garcia
  • joshuaiwhite1
    joshuaiwhite1 over 9 years ago
    <pressed ok>
    Followed by:
    Error:
    Any help?!
    -JW
    I've had a bit more uck that you.
    I'm not sure about the first error - but I think you are misinterpreting the seond error. I think Eagle creates the scr file as an intermediate script file while doing the import.
    In my case - I had some permissions problems while Eagle tried to generate the "scr" file.
    You can either change the folder where it writes the scr file - or run eagle "as administrator" in windows 7 so it breates the scr file without problems.
    I really don't know what caused your first error. I didn;t see that.
    I found this section helpful:
    http://www.cadsoftusa.com/services/simulation/
    Though I think the "ulp" is now included in V6.4.
    Richard.
