EAGLE User Chat (English) Why doesn't >LAST_DATE_TIME attribute update ?
  • Subscribers 189 subscribers
  • Views 1591 views
Hi all,
I built a "frame" device to give me a nice frame to draw my schematics
into, it consists of a few attributes that I can update >DRAWING_NAME,
>SHEET, >SHEET_NAME, >VERSION, >AUTHOR,  and >LAST_DATE_TIME
Most of these work perfectly and I can allocate them through Global
Attributes, but I can;t change the >LAST_DATE_TIME attribute, I know its
a reserved one, but it always comes out as "not saved!" when i'm editing
my schematic, I have saved the whole design multiple time but its never
picked up the save time/date like its supposed to...
I'm on Eagle Pro 6.4, on Ubuntu 12.04 LTS.
Is this because the attribute needs to be outside of the frame device ?
Any clues ?
Peter
  • kingkw1
    kingkw1 over 7 years ago in reply to e14 Contributor
    Thanks for the tip! I needed a space before the semicolon to get this to work for Eagle 9.2.2.
    i.e. "WINDOW ;"
    On 01/19/2013 05:34 PM, Warren Brayshaw wrote:
    Peter Wilson wrote:
    >> Hi all,
    >>   >SHEET, >SHEET_NAME, >VERSION, >AUTHOR,  and >LAST_DATE_TIME
    >> its a reserved one, but it always comes out as "not saved!" when i'm
    >> editing my schematic, I have saved the whole design multiple time but
    >> its never picked up the save time/date like its supposed to...
    >> Any clues ?
    >> Peter
    It's a bit tricky on Windows but does make sense.
    This is how it works for me.
    The trick is to refresh the editor view.
    Dirty the drawing (say,add a wire). The field remains the same.
    Enter in the command line WINDOW; <enter> or F2 if your assigns are default.
    "not saved!" is seen in the field.
    Save the Schematic. The field remains the same.
    The  Date and Time of the recent save is seen
    If yours is not similar then you may have a Ubuntu specific issue.
    Warren
    Perfect, thank you... just needed to enter the "window;" command and
    immediately the last saved time appears in place of "not saved!"... I've
    never had a valid time/date in the at field before... ever..
    Thanks Warren.
    Peter
    Peter Wilson wrote:
    Hi all,
    Any clues ?
    Peter
    Enter in the command line WINDOW;  or F2 if your assigns are default.
    Warren
    news.cadsoft.de
