EAGLE User Chat (English) how to start a trace from a point where there is no airwire?
  • Subscribers 189 subscribers
  • Views 579 views
  • airwire
I have 4 points as shown below, "A" connected to "B", and "C" connected to "D", and there is an air wire between "B" and "D", which eventually connects "A" to "C". However, I want to run the trace from "A" to "C". Eagle does not let me start a trace where there is no air wire. How do I go around that? How do I run the trace from "A" to "C"?
A========B
C========D
Thanks for your answer.
  • bmoe
    bmoe over 13 years ago
    Also the help comand in Eagle is very useful.
    "help route" gives you alot of useful information like the ones below.
    Ctrl+Left starts routing at any given point along a wire or via.
    Shift+Left starts routing with the same width as an existing wire.
    Center selects the layer.
    Right changes the wire bend style (see SET Wire_Bend).
    Shift+Right reverses the direction of switching bend styles.
    Ctrl+Right toggles between corresponding bend styles.
    Shift+Left places a via at the end point.
    Ctrl+Left when placing a wire end point defines arc radius.
    Found the answer here ... http://www.eaglecentral.ca/forums/index.php/mv/msg/30615/105891/
    ctrl-route does the trick.
