EAGLE User Chat (English) Needed EAGLE Layout CONTRACTOR - NOTTINGHAM
  • Views 473 views
I have an immediate requirement (28-1-2013) for an experienced contractor/consultant for schematic capture and layout using Eagle V5 or greater.
There is a mix of new PCB layout and existing PCB modification.  Some of the work involves recreating exact layouts from existing Gerbers which originated in Board Maker 3.
This work is based in Nottingham for Bartec Vodec and whilst some on-site work is required much of the work can be undertaken from home or elsewhere.
Contractor must have own valid professional license and a means to analyse existing Gerbers/BM3.
Please send me your CV, availability, and your hourly rate to be considered.
William
    autodeskguest over 12 years ago in reply to e14 Contributor
    David Cowan wrote on Tue, 06 May 2014 09:58
    I find myself looking for the same think. Did you find somebody????
    And
    would you recommend them???
    Hello David,
    In case you're still looking, EAGLE design work is the main part of our
    business at Stratford Digital.  I've personally done over 500 different
    boards in EAGLE and we'd be happy to add yours to our list.
    Contact me directly if you have any questions.
    Cheers,
    James.
    P.S. We're the company behind the forum mirror at
    http://www.EagleCentral.ca/forums.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    Take advantage of v7 License Promotion right now at
    http://www.eaglecentral.ca
    I find myself looking for the same think. Did you find somebody???? And would you recommend them???
