EAGLE User Chat (English) Need help with Connect Pin to Pad
  • Subscribers 187 subscribers
  • Views 311 views
  • pin_connection
Pls Check this Link http://clip2net.com/s/4NuXXx and tell me the PAD where i should connect first PIN and second PIN. PS. the button I designed myself. Ty for answer
Prosím, podívejte se na tenhle link http://clip2net.com/s/4NuXXx , a můžete mi říct kam mám zapojít první a druhej pin..? tlačítko jsem si navrhoval sám. Díky moc za odpověď
    On 24/03/13 10:41, LUkáš Unzeitig wrote:
    Pls Check this Linkhttp://clip2net.com/s/4NuXXx  and tell me the PAD
    We can't answer that, because your PNG doesn't show the pad numbers. You
    need to check the package definition.
