EAGLE User Chat (English) Cadsoft Eagle with Python Scripting
  • Replies 54 replies
  • Views 11304 views
I've only started using Eagle a few weeks ago, and as much as I like it, I have found what I consider some pretty fundamental features just missing. As the built in scripting language is extremely restrictive (when compared to a 'real' language like python, lua or ruby), I made an attempt to get python running with Eagle.
http://www.youtube.com/watch?v=_w7CECR7Dv8
The above is a video of a project I have been working on for the pas 3-4 days, which basically involves exposing the Cadsoft ULP and SCR to python (albeit in not the fastest way). But it does allow me to now use 90% of the ULP and all of the SCR directly from python, including the Object Heirarchies, board.grid... schematic... which have all be exposed in a pythonic way.
as an example, to get all the Instances in the schematic..
instances = Eaglepy.ULSchematic().instances()
or loop,
for instance in Eaglepy.ULSchematic().instances():
     print instance.name()
etc..
The tools in the video were very quick to knock out.. the slowest bit was figuring out the papers for approximating cubic/quadratic bezier curves with arcs, for the DXF Importer. These should be the first of many tools to come, next on the list is a group manager so I can save my selectsion.
Hopefully when I have had time to test this a bit more I will release the code to the community, along with any tools I have built. for others who might want this funtionality. (something that should be out of the box with proper bindings to a proper language imo...)
Cheers
Rob.
  • AnalogNotes
    AnalogNotes over 11 years ago in reply to Former Member
    Sorry guys, I got side-tracked with work again.  I finally figured out how to make the repository public:
    https://bitbucket.org/AnalogNotes/eagle-python
    autodeskguest over 11 years ago in reply to AnalogNotes
    Doug Wellington scribbled thus:
    http://www.element14.com/community/message/118779
    NO !  It requires a password and login name...
    Best Regards:
                          Baron.
    Former Member over 11 years ago in reply to autodeskguest
    Look at the post above Dougs. I got round to cleaning up, and putting it on github myself.. I asked Doug to remove the version I sent him, to ease confusion.
    Here is the complete code.
    https://github.com/rmawatson/PyEagle
  • AnalogNotes
    AnalogNotes over 11 years ago in reply to autodeskguest
    Sorry mate, Robin's original message didn't get propagated to the NNTP group and for some reason, even though he posted after me, his message shows up before mine on the Element14 forum.  If I had known that he was putting a repository up, I wouldn't have made mine public.  Once he created his, I set mine back to private.  Since he's the author of the code, it's better that you use his repo...
    http://www.element14.com/community/message/118806
    OK !  Thanks for update.
    Best Regards:
                          Baron.
    autodeskguest over 11 years ago in reply to Former Member
    Hi Robin
    That's a lot of work you have done.
    Thanks for sharing
    Warren
    Excellent work!
    I've been trying to import eagle schematics into Python now that they in XML format.
    So far I have a script that can import and return iterable objects for layers and parts.
    segments can be itstill need some work
    libraries are broken.
    If this is at all helpful, you can find it here:
    https://github.com/uid89626/Eagle
    That's great foxx00!
    Here are a couple quick tools I wrote to explore EAGLE files.  The first is
    a short Python script that just displays the top few node levels.  Save it
    to an executable file (add a shebang if you need it) and put the EAGLE file
    name on the command line:
    import sys
    import xml.etree.ElementTree as ET
    if len(sys.argv)  - read EAGLE XML file" % sys.argv[0]
      sys.exit()
    input_file = sys.argv[1]
    try:
      input_string = open(input_file).read()
    except:
      print "Couldn't read %s..." % input_file
      sys.exit()
    try:
      tree = ET.fromstring(input_string)
    except:
      print "Couldn't parse file, is this an EAGLE 6 document?"
      sys.exit()
    print "%s consists of:" % input_file
    for child in tree:
      print child.tag
      for grandchild in child:
        print "  ", grandchild.tag
        if grandchild.tag == "schematic" or grandchild.tag == "board":
          for greatgrandchild in grandchild:
            print "    ",  greatgrandchild.tag
    I've been playing around with functional programming lately, so the second
    is a quick Scala (Scala is rapidly becoming my favorite language!) script
    that gives you node sequences for each of the main file sections, along
    with a couple examples of iterating through them (the filename is
    hard-coded in this one at the moment, sorry):
    import xml.XML
    val fileName  = "test.brd"
    val eagleFile = XML.loadFile(fileName)
    // search for drawing node, then for each child node
    // length is zero if not found (e.g. you won't find a
    // schematic in a board file...).  Comment out as
    // desired to speed things up.
    val settings  = eagleFile \ "drawing" \ "settings"
    val grid      = eagleFile \ "drawing" \ "grid"
    val layers    = eagleFile \ "drawing" \ "layers"
    val board     = eagleFile \ "drawing" \ "board"
    val schematic = eagleFile \ "drawing" \ "schematic"
    print("\n\nUsing xpath to search for layers:\n\n")
    for (l <- layers \ "layer" ) println(l)
    println
    val allLayers = (layers
    "layer")
    print("\n\nNow iterating through layers in a loop:\n\n")
    allLayers.foreach{ l =>
      val layerNumber = (l \ "@number").text
      val name = (l \ "@name").text
      val visible = (l \ "@visible").text
      println(s"Layer $layerNumber, $name, is visible: $visible")
    I've been using XML Copy Editor and Firstobject XML Editor to display and
    edit the files...
    Doug
    Former Member over 11 years ago in reply to AnalogNotes
    Doug,
    When I click on the link (I am already logged into my Bitbucket account), I get the following message:
    You do not have access to this repository.
    Use the links at the top to get back.
    Second question:
    Do these links contain the same content?
    https://bitbucket.org/AnalogNotes/eagle-python vs https://github.com/rmawatson/PyEagle
    Anton,
    You can find the repository at http://https://github.com/rmawatson/PyEagle
    Doug
