EAGLE User Chat (English) Cadsoft Eagle with Python Scripting
  • Replies 54 replies
  • Views 11360 views
I've only started using Eagle a few weeks ago, and as much as I like it, I have found what I consider some pretty fundamental features just missing. As the built in scripting language is extremely restrictive (when compared to a 'real' language like python, lua or ruby), I made an attempt to get python running with Eagle.
http://www.youtube.com/watch?v=_w7CECR7Dv8
The above is a video of a project I have been working on for the pas 3-4 days, which basically involves exposing the Cadsoft ULP and SCR to python (albeit in not the fastest way). But it does allow me to now use 90% of the ULP and all of the SCR directly from python, including the Object Heirarchies, board.grid... schematic... which have all be exposed in a pythonic way.
as an example, to get all the Instances in the schematic..
instances = Eaglepy.ULSchematic().instances()
or loop,
for instance in Eaglepy.ULSchematic().instances():
     print instance.name()
etc..
The tools in the video were very quick to knock out.. the slowest bit was figuring out the papers for approximating cubic/quadratic bezier curves with arcs, for the DXF Importer. These should be the first of many tools to come, next on the list is a group manager so I can save my selectsion.
Hopefully when I have had time to test this a bit more I will release the code to the community, along with any tools I have built. for others who might want this funtionality. (something that should be out of the box with proper bindings to a proper language imo...)
Cheers
Rob.
    autodeskguest over 9 years ago in reply to rick_b
    rickb wrote on Mon, 20 February 2017 15:47
    Quote:
    Do you mean the Python scripting?
    Yes, thanks.
    Sorry mate, I didn't get to try it out.  We had a (late) Chinese New Year
    celebration at the Bagua school Saturday and the little lady and I spent
    most of Sunday out of town with family.
    I'm now on the fence about how much more effort to put into the Python
    thing.  I had started a book on advanced EAGLE use and I was including
    writing scripts and ULPs and how to manipulate the XML files externally.
    With the changes in the EAGLE world lately, part of me is angry enough to
    motivate me to finish up the external program that lets you directly
    manipulate the XML files, but the other part of me is disgusted enough to
    want to drop it all and just walk away.  End of an era.  Sigh...
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • rick_b
    rick_b over 9 years ago in reply to autodeskguest
    I understand your frustration. I bought 7.7 before the official
    announcement and feel the same way. I will continue to use it until it no
    longer meets my needs or until Kicad meets my expectations, which ever
    happens first. I would like to see what you have written, however rough it
    may be for educational purposes.
    Rick
    rickb wrote on Mon, 20 February 2017 19:48
    happens first.
    I see that there is a python scripting API for KiCad.  I'm going to work
    with that a bit.  Also, while I'm not a huge scheme fan, gEDA does have
    guile scripting.  In particular, this page about hierarchical blocks in
    gEDA looks very interesting to me:
    http://www.bourbonstreetsoftware.com/GEDABlocks.html.  He even uses "make"
    which for me as a Unix guy is very appealing!
    Quote:
    I would like to see what you have written, however rough it may be for
    The general outline of the book is to talk about command line use and
    scripting, then how to make menu changes and key assignments, followed by a
    couple chapters on writing ULPs to create scripts.  Then I used Python to
    take a look at the XML files directly.  For my example code, I
    reimplemented my arrange and distribute ULPs in a Python script you run
    from the command line.
    In the next chapter, I started building a graphical interface to view the
    files.  This turned into mostly a library and BOM manipulation tool, sort
    of an external http://www.bobstarr.net/pages/downloads.html if you will.  I
    considered using PyQt for the GUI, but the licensing didn't work for me, so
    at that point, I switched to using Java.  I've got quite a few of the basic
    functions implemented, so you can open an EAGLE file, change attributes,
    move items, lock and unlock, save, etc.  Next, I was going to render the
    board file and display it in 3D space so that you could fly by and see the
    back side.  I've done this kind of thing before with POV-RAY, Sketchup,
    Blender, TurboCAD, and Lightwave, but it would be nice to simplify that
    process.
    I think the last thing I'm going to do is implement some export function so
    that I can convert all of my current designs to KiCad or gEDA.  And I have
    to say, the http://www.altium.com/eagle-switch/circuitstudio/ deal is
    sounding mighty nice - for less than the cost of a year of EAGLE Premium
    subscription, you can get a perpetual license.  At the end of the year,
    I'll have saved $5 and have a usable copy of Circuit Studio...
    On 21.02.2017 19:17, Doug Wellington wrote:
    I considered using PyQt for the GUI, but the licensing didn't work for me, so
    For a more liberal license, you should have considered wxPython instead.
    Python seems a much more natural choice for these tasks than Java.
    Also, it would allow for easier integration if you really want to
    migrate to KiCad. The PCB part of KiCad has a Python console already.
    I would expect the Schematic part to follow sooner or later.
    Dietmar
    Dietmar
    Dietmar Schwertberger wrote on Wed, 22 February 2017 12:32
    instead.
    Thanks, part of my issue is that I was also writing in C++ and I didn't
    want to have to release that source code.  It's my code, I wrote it and I
    want to keep it private.  Over the years I have grown weary of people
    contacting me demanding my source code, my schematic and board files, and
    my gerbers.  It's hard to make your investment back when someone can grab
    your work and match or beat your time to market and undermine your pricing.
    Anything with GPL licensing is out for me because of that
    For scripting, rapid prototyping and as a language to use for teaching,
    Python is fantastic.  Because of it being interpreted though, there is no
    way to effectively control your IP.
    instead.
    Also, switching to the Java world lets me use Groovy, Scala, Clojure, and
    even Jython or JRuby all together...
    FWIW, the Java ecosystem is fantastic.  The build, test, code analysis,
    continuous integration, etc., tools are great!
    Thanks, part of my issue is that I was also writing in C++ and I didn' > want to have to release that source code.  It's my code, I wrote it
    and I> want to keep it private.  Over the years I have grown weary of people
    Put your core C++ code into a .pyd (i.e. actually a DLL).
    Still you can control your code from Python, offering a scripting
    interface without much effort.
    The wx license is not GPL. It is LGPL, but even allows to distribute
    binaries on your own terms. So basically, it's not much different from
    MIT, BSD or similar licenses for any practical application.
    It's also a great language to implement large applications, either GUI
    or web based. Implementing GUIs in C++ seems to be a huge waste of
    resources. The learning curve for GUIs is a bit steep, just as for C++.
    For this reason I started improving the wxGlade GUI builder last year.
    If you go for wx, you should have a look at the current wxGlade version
    from the repository.
    (Documentation update is work in progress and not yet online.)
    Well, there are ways, but these are a bit complicated. I have one
    application where I'm using a dongle for Python code and .pyd extensions.
    But protection of the Python code requires a custom Python runtime.
    For extension of other people's code, that's probably not an option.
    On the other hand, don't forget that Python bytecode might be easier
    to decompile, but it's also possible for C++ code. I think there are
    quite powerful reverse engineering tools for compiled binaries.
    Dietmar
