EAGLE User Chat (English) Eagle PCB design question. Please Help!
  • Subscribers 187 subscribers
  • Views 427 views
Dear all,
I am new to Eagle and I am current designing a PCB which have mixed signals. It is a 4 layer design with Signal, Ground, Vcc, Signal. Since I have an Analog ground and Digital ground, how can I create 2 ground supply parts, ie AGND and DGND since when I am changing their name or value, they are not seperating.
Please help me guys! Thanks!
    autodeskguest over 13 years ago in reply to autodeskguest
    Am 20.04.2013 23:22, schrieb Mike Malherbe:
    On 4/15/2013 12:23 PM, Savio Galea wrote:
    Dear all,
    http://www.element14.com/community/message/74196#74196
    Hello Savio,
    First click on the letter i in the command button area, then click on
    one of the ground plane borders.  The Properties Box will appear where
    you can select the amount of isolation for each ground and also the
    order of priority by setting the Rank.  Repeat for the second ground
    plane and set Rank to the next higher number.  When you click Ratsnest
    you will notice the two ground planes will be separated.
    Best Regards,
    Mike
    Additional I might say that you should use different symbols for
    different grounds. Those can be found in the supply libraries. Of course
    you can create them yourselves image
    Joern Paschedag
    Dear all,
    Hello Savio,
    Best Regards,
    Mike
