EAGLE User Chat (English) Re: optimize after autoroute?
  • Subscribers 178 subscribers
  • Views 275 views
Former Member over 17 years ago
  • angelus9
    angelus9 over 17 years ago
    I have been using the Autorouter it it works quite well - Maximize the via
    numbers (why limit this) and set up your preferences and let it rip.
    I then go back and pretty up the traces - then it is done.
    I am working on a more complex board which will give it a good test.
    Anyone else with experience with this tool who would comment on do's and
    don'ts?
    Don
    "Harald Kipp" <eagle@egnite.de> wrote in message
    news:fhf112$i1$1@cheetah.cadsoft.de...
    Mark Lucia schrieb:
    With some larger projects, I'll run the auto router with all optimization
    turned off, simply to get a feel for part placement.
    I'm doing this sometimes as well.
    I found that if I then enable the optimizers, and run the auto router
    once again, nothing changes - I suspect because the auto router no longer
    knows about the vias - (shows VIAS: 0)
    Not sure, if I understood this correctly. AFAIK, the autorouter will not
    touch any trace, which had been routed already. It will route airwires
    only.
    Harald
    autodeskguest over 17 years ago in reply to angelus9
    Are you serious ??
    for high speed or low noise design routing is critical, and this
    includes what side the tracks are on, and where the vias are
    Numerous vias can also affect reliability, manufacturabilty, EMC.
    Most of my design fall into this category, in which case the autorouter
    is very poor.  Personally I never use it.
    In general low cost autorouters are appropraite for moderate speed
    digital designs on a minimum of 4 layers.  New users should first learn
    to appreciate the importance of current flow in the layout before
    considering touching the autorouter.
    Anything else should pretty much be routed by hand.
    Too often the autorouter just encourages lazy routing and too many
    newbies use it and don't understand the importance of return current
    flow in design of optimum PCB layout.
    In which case my main comment is do not use the autorouter for single or
    two layer designs.
    cheers
    David
  • angelus9
    angelus9 over 17 years ago in reply to autodeskguest
    I agree with you your observations!
    All speed sensitive or impedance critical routes should be done by hand -
    first.  Route the clock, impedance matched lines, power traces first by
    hand.
    I use it on four layer boards typically and rarely go above 50mhz digital
    designs.  I do alot of low frequency analog and motor control, embedded
    processor stuff which is not layout critical. typically.
    Use the right tool for the right job.  I move things around a little bit
    after it is done - I think the most offensive thing the autorouter produces
    is more vias, which I don't think is a big deal today, and it is very useful
    for  lower speed designs and complex IO type of stuff.
    On the other hand, it is pretty fexible and it doesn't seam to put many
    crazy routes around the board.  For the price, it is very good....
    Don
    "David" <david@nospam.com> wrote in message
    news:fo23bf$be5$1@cheetah.cadsoft.de...
    via numbers (why limit this) and set up your preferences and let it rip.
    Are you serious ??
    for high speed or low noise design routing is critical, and this includes
    Most of my design fall into this category, in which case the autorouter is
    In general low cost autorouters are appropraite for moderate speed digital
    designs on a minimum of 4 layers.  New users should first learn to
    appreciate the importance of current flow in the layout before considering
    Too often the autorouter just encourages lazy routing and too many newbies
    use it and don't understand the importance of return current flow in
    two layer designs.
    cheers
    David
