EAGLE User Chat (English) Shared libraries
  • Subscribers 187 subscribers
  • Views 1239 views
Shared libraries
We have a number of Eagle licences and have been running multiple copies of
Eagle at the same time with people working on different pcbs at the same
time.  We have been sharing libraries on a network drive but this appears
to cause some syncing problems with changes to libraries being lost even
when the libraries are only accessed through Eagle by one person.  I'm
assuming another user who perhaps is not using Eagle at that time is
somehow replacing the library via Windows sync.
I know this sounds like a Windows problem but what I'm really asking is, is
there a recommended way of sharing libraries between Eagle users on a
network?
I do realise that some sort of discipline must be in place to stop two
users simultaneously modifying the same library but that manageable.
    autodeskguest over 13 years ago in reply to autodeskguest
    Robert Johnson wrote on Tue, 21 May 2013 01:44
    James Morrison wrote:
    Robert Johnson wrote on Mon, 20 May 2013 03:30
    Phil Dixon wrote:
    With Eagle V5 we used version control (CVS) and personal libraries
    for
    each
    engineer. Depending on which engineer created the part symbol, it
    went
    into
    either the EngineerA.lbr, EngineerB.lbr, ... etc library. That
    prevented
    EngineerA from checking something into a common library file in the
    version
    control system, and then having it overwritten by a check-in from
    EngineerB.
    Only EngineerA had write access to the EngineerA library, EngineerB
    the
    EngineerB library, etc. Note that even version control locks don't
    fix
    the
    issue of binary file overwrites of common files unless a
    higher-level
    management of the files is implemented. We implemented that
    higher-level
    management of a few core shared libraries by giving just one
    engineer
    at a
    time write access to them.
    I'm not a revision control expert by any means, but with subversion
    we set
    it up to require a lock files *.sch and *.brd.  When you check
    those out
    by
    default they are read-only in the OS.  When you get the lock it
    then
    becomes writable.  Thankfully EAGLE checks that when you try to
    save it
    (unlike Word or Excel which only check when you load the file).
    While it is possible to bypass the lock and set the file read-only
    manually, in general this works very well and ensures that only one
    person
    can write the file at a time.  I think this was one of the
    improvements
    from CVS to subversion.
    HTH, cheers,
    James.
    Hi James,
    I was getting a bit pedantic when I wrote about lock issues image Like
    most
    version control systems subversion doesn't lock across multiple
    developer
    branches, hence if DevA is working on BranchA and DevB on BranchB and
    both
    are working on FileC, placing a lock on FileC in the trunk won't
    read-only
    lock the files in the developer branches. This is a software/web
    development
    issue really; working with Eagle libraries in branches isn't something
    most
    sane Eagle users would (or should) consider. For Eagle V5 I'd
    definitely use
    subversion these days if I was starting from scratch, for precisely the
    binary lock features you mention. Obviously, the XML text file format
    of V6
    solves the problem even more elegantly.
    Agreed, branching is something that would likely just cause more problems
    than it solves, at least in general.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Phil Dixon wrote:
    With Eagle V5 we used version control (CVS) and personal libraries for
    each
    engineer. Depending on which engineer created the part symbol, it went
    into
    prevented
    version
    EngineerB.
    Only EngineerA had write access to the EngineerA library, EngineerB the
    EngineerB library, etc. Note that even version control locks don't fix
    the
    issue of binary file overwrites of common files unless a higher-level
    higher-level
    management of a few core shared libraries by giving just one engineer
    at a
    I'm not a revision control expert by any means, but with subversion we set
    it up to require a lock files *.sch and *.brd.  When you check those out
    by
    default they are read-only in the OS.  When you get the lock it then
    becomes writable.  Thankfully EAGLE checks that when you try to save it
    manually, in general this works very well and ensures that only one person
    can write the file at a time.  I think this was one of the improvements
    HTH, cheers,
    James.
    Hi James,
    I was getting a bit pedantic when I wrote about lock issues image Like most
    version control systems subversion doesn't lock across multiple developer
    branches, hence if DevA is working on BranchA and DevB on BranchB and both
    are working on FileC, placing a lock on FileC in the trunk won't read-only
    lock the files in the developer branches. This is a software/web development
    issue really; working with Eagle libraries in branches isn't something most
    sane Eagle users would (or should) consider. For Eagle V5 I'd definitely use
    binary lock features you mention. Obviously, the XML text file format of V6
    each
    into
    prevented
    version
    EngineerB.
    the
    higher-level
    at a
    it up to require a lock files *.sch and *.brd.  When you check those out by
    HTH, cheers,
    James.
    of Eagle at the same time with people working on different pcbs at the
    same
    is there a recommended way of sharing libraries between Eagle users on a
    network?
    With Eagle V5 we used version control (CVS) and personal libraries for each
    engineer. Depending on which engineer created the part symbol, it went into
    either the EngineerA.lbr, EngineerB.lbr, ... etc library. That prevented
    EngineerA from checking something into a common library file in the version
    control system, and then having it overwritten by a check-in from EngineerB.
    EngineerB library, etc. Note that even version control locks don't fix the
    management of the files is implemented. We implemented that higher-level
    management of a few core shared libraries by giving just one engineer at a
    With the Eagle V6 XML format, standard version control is much easier. Now
    EngineerA and EngineerB can use common library files and the changes are
    merged appropriately. Conflicts are rare provided the engineers aren't
    modifying the same device at the same time. If they do occur, they are
    resolved using the standard merge mechanisms.
    I'm not familiar with Windows or Windows Sync (we're entirely Linux-based),
    but I'd highly recommend setting up a true version control system for all
    your Eagle projects, ie, the schematic and board files as well as the
    libraries. Git, subversion, Mercurial, or whatever works on Windows.
    Preferably with a remote repository. It's cheap insurance against disaster.
    Oliver Betz wrote on Fri, 17 May 2013 10:18
    appears
    even
    I'm
    our libraries are on a network share since 20 years or so and I
    experienced any problem. I have to admit that I'm still using Eagle 5.
    I would highly recommend using a revision control system (subversion and
    git are both free).  That way you use a tool that is specifically designed
    for multiple people accessing the same file.  And you get complete revision
    control as a bonus!
    In V5, the files are binary so you can setup subversion to auto-lock based
    on extension.  This means that if one person locks the file no one else is
    allowed to check in changes, in fact, their local copy is read-only until
    they get the lock.  This keeps 2 people from making changes at the same
    time.
    With V6, the library file is now text based (XML).  So the tool will allow
    multiple people to work on the same file and merges the changes.  If you
    happen to edit the same set of lines then it will ask you how you want to
    resolve.  This is unlikely to happen , though possible.
    The only downside is that CadSoft didn't change the extension from V5 to V6
    so it's difficult to live in a world with both versions (like we have to).
    So we end up having locks on our V6 files even though it isn't necessary
    since we must have locks on V5 files.  That was poor planning by CadSoft.
    Cheers,
    James.
    Oliver
    Oliver Betz, Munich
    despammed.com is broken, use Reply-To:
