    • Avnet Boards Community
EAGLE User Chat (English) A Symbol without a Package?
  • Subscribers 172 subscribers
  • Views 670 views
mamikee
mamikee over 17 years ago
I wish to annotate a schematic by adding the parts that connect (via
connectors on the PCB) but don't which to have packages show up to be placed
on the circuit board.
Can anyone illuminate the proper way to do this?
Thanks in advance,
Mike Berry, Colorado
  • mamikee
    I assume there is no provision for doing this in the current release.
    I will add this as a feature request.
    For now I've done the annotation by adding text to the schematic symbol
    layer.
    mcb
    "Mike Berry" <mcb@IronXfer.com> wrote in message
    news:foaib9$rra$1@cheetah.cadsoft.de...
    placed on the circuit board.
    Thanks in advance,
    layer.
    there is no problem making a symbol with out a package.
    see for example the eagle frames library
    cheers
    David
  • mamikee
    Ah, that is a perfect example!
    So my next question is if you have an existing device is it easy to remove
    the package?  Could not find a way to do that.
    Thanks!
    mcb
    "David Moodie" <dgmoodie@onetel.com.cut_this_off> wrote in message
    news:fof8mu$6uc$2@cheetah.cadsoft.de...
    layer.
    cheers
    David
    If you have pins in the symbols, you need a package for it. If you use only
    other drawing primitives,  you can get by without a package.
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    Thanks!
    mcb
    1. Avoid top posting. While OK for personal mail it doesn't work in newsgroups
    2. To remove a package from a device simple right click on the package name
    and select delete.
    cheers
    Former Member over 17 years ago
    placed
    I'd define a new device variant that uses the connector's package. So on the
    schematic it shows up as your device, but on the board it shows up as the
    footprint of the connector.
    You might even make the symbol be something that indicates that it is a
    connector and the device that connects via the connector. See the attached
    offboard_led.bmp for a quick example of what I mean. Make a device with that
    symbol and the package from the 2 pin connector, et voila!
       Keith
