EAGLE User Chat (English) EDWin import
  • Subscribers 177 subscribers
  • Views 511 views
EDWin import
Someone's asked me to etch a board using an EDWin design,
would it be possible to import this in eagle somehow? (just the pcb layout)
Or is it gerber's thats the deal here? (basically all I need is being able to
plot the layout to the printer using drafting film)
I've found gerbers to be overly complicated for this simple task
and there's always been something to mess it up....
//Greg
    //Greg
    I you are going to etch a board at home, then the board needs to be
    printed 1:1 using a laser printer.  This works well for the
    press-and-peel or iron-on methods.  A Gerber is needed if you want a PCB
    fabricator (PCB house) to make a board.  Some PCB fabs offer a low-cost
    service for a double sided plated through board with no solder mask and
    no silk-screen.
    Sorry, I don't know about EDWin, and don't want to know.
    -Dave Pollum
    //Greg
    I you are going to etch a board at home, then the board needs to be printed 1:1 using a laser printer.  This works well for the
    press-and-peel or iron-on methods.  A Gerber is needed if you want a PCB fabricator (PCB house) to make a board.  Some PCB fabs
    offer a low-cost service for a double sided plated through board with no solder mask and no silk-screen.
    -Dave Pollum
    Thanks but I already know this image
    //Greg
    //Greg
    Can you not get the edwin user to either
    1. print out the appropriate layers and give you the acetate/tracing paper.
    2. get them to print to pdf as 1:1 of the required layers, verify it and
    then give you the pdfs
    cheers
    David
    On 2/7/08 3:11 PM, in article fofol6$g5q$1@cheetah.cadsoft.de, "Greg"
    As has already been mentioned, you could print to PDF as 1:1.  But if they
    have gerbers then why not just use a gerber viewer to load them and then
    print them 1:1 on a laser printer.  That is what I would try to do first.
    Gerber is intended to keep dimension information so it can be trusted to do
    that.  PDF is for display purposes, I'm not sure I'd trust it nearly as
    much.
    Cheers,
    James.
    James Morrison
    www.eagletoolkit.com
    Long-time EAGLE User and EAGLE Enterprise Toolkit Author
    I've only had problems displaying gerber files I'm afraid....
    Not saying it wring woith the gerbers, just my lack of understabnding image
    "James Morrison" <spam2@stratforddigital.ca> wrote in message news:C3DA731B.108D2%spam2@stratforddigital.ca...
    much.
    Cheers,
    James.
    James Morrison
