EAGLE User Chat (English) alignment of packages when transfer them to the routing area
  • Views 583 views
  • header
  • allignment
as you can tell, new to eagle. one of my head scratching is how to allign the parts with specific distances as i am trying to make sure the board i produce will siton top of an arduino board headers!! beside how to get the distances for the seperation of arduino headers and i could not find them documeneted.
regards
mohammed alkindy
    autodeskguest over 13 years ago in reply to autodeskguest
    The official Arduino boards are laid out using Eagle 6. If you go to the
    Arduino Hardware page (http://arduino.cc/en/Main/Products) and look at
    any of the boards you'll find a downloadable Zip file containing the
    Eagle design for that board. That's probably the easiest way of making
    sure your boards match the official design.
    In general, when trying to place a component precisely, it's often
    easiest to bring up the "info" pop-up for the component and directly
    edit the component location.
    meaning: open the arduino files in question, note down the coordinates
    of the connectors (info dialog), then place the corresponding
    connectors in your board accordingly (info dialog or add command with
    coordinates as parameter).
    Lorenz
    e14 Contributor over 13 years ago in reply to autodeskguest
    thak you for your response, hope to learn from all.
    -Reece
    Am 01.06.2013 18:04, schrieb mohammed alkindy:
    regards
    mohammed alkindy
    http://www.element14.com/community/message/78390#78390
    The easiest I think, take the coordinate 0.0 as a reference and then set
    and change the grid according your needs (1/10000 mm if you like).
    On the top left you can see the distance from the/your reference point.
    (you can set your own reference too). Help grid.
    Joern Paschedag
