EAGLE User Chat (English) Changing Signals/Traces
  • Subscribers 177 subscribers
  • Views 140 views
Greetings,
   When I try to draw a signal in the board layout, I get an
backannotation error, meaning that it is unable to put the same signal
in the schematic.
   What I need to do is to change a power trace so it has the shortest
path to one of the smd pads.  How do I do this and not have the
schematic look like spaghetti?
Thank you,
A
    Amer wrote:
    Greetings,
    in the schematic.
    Thank you,
    A
    If you only want to change the path a trace takes, just use the "ripup"
    command to remove the existing trace and then route the new one manually.
    John G.
