EAGLE User Chat (English) Supply layers Ground planes and polygons
  • Subscribers 177 subscribers
  • Views 275 views
Greetings,
   I am trying to get some insight about supply layers, ground planes
and polygons.
   I have a problem that fill polygons leave a clearance away from a
trace of the same signal.  They only seem to connect at pads with
thermals.  Is that proper? Maybe I do not understand the concept.
   When I set a supply layer (eg. GND) the autorouter does not want to
route.  The manual says to use polygons instead but I still have the
problem above.
   Any insight about how supply layers should be used to get a "quiet"
ground plane with minimal currents?
Thank you,
-- A
    Amer wrote:
    Greetings,
      I am trying to get some insight about supply layers, ground planes and
    polygons.
    problem above.
    Thank you,
    -- A
    Either use supply layers or polygons but not both on a layer.  From help
    layer "Supply layers are viewed "inverted"".
    If all you want it a single signal layer of copper and not any traces
    use a supply layer. But it is better and more flexible to remove the $
    from the layer name to make it a regular layer and then add named
    polygons as required. Traces can be also routed on this layer without a
    problem.
    Paul R.
