EAGLE User Chat (English) DRC Errors after Autorouting
  • Subscribers 178 subscribers
  • Views 420 views
Why do I get DRC errors after I autoroute.  The autorouter places the
vias too close to the pads so when I do a DRC check I get the warnings.
And this happens without any changes to the Design rules.
Any ideas?
Thank you.
-- A
  • Richard_H
    Richard_H over 17 years ago
    Any ideas?
    Thank you.
    -- A
    Could you give us more details, for example, which EAGLE version?
    Best would be to send me your board file with private mail.
    So I could check it.
    Richard Hammerl
    autodeskguest over 17 years ago in reply to Richard_H
    Any ideas?
    Thank you.
    -- A
    I am using 4.16r1 lite.  I tinkered with it a little more and found out
    that it is dependent on the routing grid.  If you use too small a grid,
    the vias are placed too close to the pads.  I started with a courser
    grid (10mil) and went to a finer one (5mil) and it seemed  seemed to fix
    the problem.  However since the 5 and 10 grids overlap, why would EAGLE
    place the vias too close when starting with the 5mil grid?
  • Richard_H
    Any ideas?
    Thank you.
    -- A
    This should not be a matter of grid setting. As I alreasdy wrote,
    please send the board file and tell me what to do, so that I can
    reproduce this error.
    Richard Hammerl
