EAGLE User Chat (English) Gerber of negative plotted layer
  • Subscribers 187 subscribers
  • Views 703 views
Hi.
I am almost reaching the finish of my first 4 layer project with Eagle
4.14r2. But struggled. I am very much appreciate if somebody give me
comment.
I set the name of layer 2 and 15 as $GND and $VDD, respectively. So,
both are successfully connected with power. Both layers are showed as
negative image on Eagle PCB editor. This is as written in the manual.
After generated Gerber, I confirmed result with Viewmate. Both $GND and
$VDD layer is showed as negative. OK.
But I found all 4 layers Gerber has following declaration.
%IPPOS*%
%LPD*%
That mean, all layer data is positive plotting. Strange. As I described
above, inner layer ( 2 and 15 ) is negative, and outer layer ( 1 and 16
) is positive.
Is this usual among the CAD vendor and PCB manufacturer? If yes, how
come manufacturer can know given file is positive or not?
Thank you in advance.
Suikan
    Bert, Uwe,
    Thank you very much. It seems better to use the positive image by
    polygon, rather than negative image by power plane.
    I will modify my board.
    Again,
    Thank you.
    Bert Menkveld <bert@betech.biz> wrote:
    However, I would avoid the entire issue by not using the power layers.
    Instead, use the inner layers as standard layers, and simply draw GND and
    VDD polygons on those layers.  That way you can view them in an easily
    understood way in Eagle, and there will be nothing different about the way
    these layers are plotted in the Gerber files.  Also, this approach allows
    you to draw other traces on the inner layers, which is often very useful.
    I agree with Bert. With supply layers, it is also easily done that you
    output the vias together with the ground plane. That way, the whole ground
    plane gets isolated and useless.
    Been there, done that image
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    Suikan wrote:
    Hi.
    comment.
    and $VDD layer is showed as negative. OK.
    %IPPOS*%
    %LPD*%
    described above, inner layer ( 2 and 15 ) is negative, and outer
    layer ( 1 and 16 ) is positive.
    Suikan
    I can't comment on the apparent contradictions in the Gerber files.
    Bert Menkveld
