EAGLE User Chat (English) Help for a newb
  • Replies 7 replies
  • Subscribers 187 subscribers
  • Views 968 views
Help for a newb
I am looking to etch my own pcb for a small project I am working on. I plan
on designing the circuit with Eagle. The circuit itself is very simple, but
requires a lot of traces. It will consist of 12 piranha rgb common anode
leds laid out evenly on a 4x3" board, for which each of the r, g and b
channels will be connected to one tlc59116 driver (so one driver per
color). An external connector provides vcc, gnd and i2c comms.
Now, I know I could do this with a perfboard and lots of wires.
My question is: given the number of traces, does this even sound reasonable
on a one layer pcb (and jumpers on top as needed)? I kind of feel this
really would require more layers, therefore requiring a professionally-made
pcb (which defeats the purpose of diy/hobby/do it for the fun of it)
Keep in mind this is for a personal project, for the fun of learning new
things.
Any advice appreciated.
    autodeskguest over 13 years ago in reply to autodeskguest
    I have to admit trying to place components in the best possible manner,
    with the combination of routing the traces nicely, is daunting, as I have
    absolutely no experience. I have another project I could try my hand at,
    but even then, my brain's not yet wired for it (ha ha). Thanks for the
    advice, I appreciate it!
    On 12/07/13 14:54, martin helie wrote:
    Hi Rob,
    thanks for the advice. How do you handle vias in such a scenario?
    That depends where the vias are. Out in the open, a bit of wire through
    the board - or more specifically, there are pins available for precisely
    that purpose, shaped so that you can push them into the hole and they
    are held tight while you solder them.
    Seems
    like it could be tricky. Eagle's auto router handles all traces of my
    circuit if I use top and bottom layers, but the number of vias it creates
    is a concern.
    Personally I would not use the autorouter for any sort of home-etch
    board. Actually, I don't use it for boards I get made professionally. If
    you do use it, expect to have to clean it up a LOT before you get the
    minimal via solution you need.
    On 07/12/2013 09:54 AM, martin helie wrote:
    Hi Rob,
    thanks for the advice. How do you handle vias in such a scenario? Seems
    is a concern. I have tried to increase the cost of vias, but that really
    seems to limit its ability, and it leaves too many crisscrossing airwires
    for me to handle afterwards. I can probably tweak it further and manually
    route more traces but getting a sense of what I am getting into wrt vias
    would be helpful.
    TIA.
    For doing a single sided home made I would route as 2 sided route and
    manual edit to move as many traces to one side of the board as you can.
    For the non plated side just add jumpers from via to via for the non
    plated side traces.
    Since the jumper wires can cross over unlike traces you should be able
    to reduce the density on the trace side and have less via then the two
    sided route.
    Or go the 3 boards at $5 per sq inch from http://batchpcb.oshpark.com/
    Note I have use batchpcb.com before the close and not oshpark. The silk
    and solder mask makes the prototype process easy.
    Paul
    Hi Rob,
    would be helpful.
    TIA.
    On 11/07/13 16:30, martin helie wrote:
    Don't rule out the option of a double-sided PCB. I've done them
    home-etched in the past (much of my first computer was built that way).
    The trick is to put sufficient corner markers on the layout so that you
    can achieve good alignment of the two sides.
    Rob
    On 7/11/2013 8:30 AM, martin helie wrote:
    things.
    If it is for the fun of learning I would say go ahead and give it a try
    and see if you can fit the traces.
    This is the fun part, like a puzzle where you may or may not have all
    the pieces.
    Anyone? Bueller?
