EAGLE User Chat (English) Why ERC does not detect unconnected pins
  • Subscribers 178 subscribers
  • Views 467 views
The subject sums it up. I relied on the ERC, when making my schematic, to
check the connections. There were no warnings or errors regarding
unconnected pins. The places that the pins are not connected are only
visible when zooming in so that a gate takes the entire screen.
How is this prevented?
Matt
    Former Member over 17 years ago
    Use frequently "show" to higlight net(s) & pin(s).
    This is a workaround, which still could have resulted in the mistake and is
    not practical for large designs. I guess the ERC does not function the way
    it is described in the help menus.
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> wrote in message
    news:fqmplj$t1n$1@cheetah.cadsoft.de...
    I have found two main reasons that causes this.
    1. Your grid is set too fine. Use a coarser grid,
    normaly 0.01" or 0.005 is ok. This forces the net
    to snap correctly to the pin.
    2. The main cause would be the pin type. If the
    pin is passive or NC then ERC will not detect the
    fault and rightly so. Pins marked as IN OUT or
    both will give you a result.
    Hope this helps
    Rudi
    Hello Matt Barrett !:
    Best way would be you send us an example ... There are many reasons
    possible and we can only speculate image
    regards
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    http://www.complex.org.pl/
