EAGLE User Chat (English) Several independently placeable package footprints ?
  • Subscribers 177 subscribers
  • Views 204 views
Is there a way to create a single device that has several independently
e.g.
I want to create a new library part for the LUXEON Star/O
http://www.lumileds.com/pdfs/DS23.pdf  (page 4)
This is a LED and a lens, mounted on a metal heat-sink plate. There are
SMT style solder pads on the top of the device, but these would not be
directly accessible to the board routing.
I want to place drilled solder pads and connect to the LED using wires,
but I don't want to fix the position of the drilled pads relative to the
LED module.
I'm working around it at the moment, by using two solder pads with a
loose i.e. disconnected luxeon LED device on the schematic just there to
occupy space on the board.
RJB
    e.g.
    LED module.
    RJB
    "I don't want to fix the position of the drilled pads relative to the
    LED module."
    ?? Why not ??
    -Dave Pollum
