EAGLE User Chat (English) Through Hole pads
  • Subscribers 177 subscribers
  • Views 342 views
Through Hole pads
Greetings,
   I am having trouble figuring out how to make the following 5 pad mini
USB connector: http://www.molex.com/pdm_docs/sd/5000751517_sd.pdf
When I use the pad tool, the "elongated" pads are not round and they
have different lengths than what is suggested.
Any ideas are greatly appreciated.
Thank you,
-- A
    David Pollum wrote:
    AFAIK, you will need milled slots for the part's mounting ears.  If
    milling is expensive, then you can use a single large hole for each ear.
    This large hole may be so large that solder doesn't fill in the hole
    and therefore doesn't solder the ear.
    HTH
    -Dave Pollum
    Thank you for your help.  My question is also the regular pads, not just
    the ears: when I specify a diameter for the elongated pad, its sets its
    length automatically.  How can I get around this? I was thinking of
    drawing my own shapes in the pads layer and also in stop layer,
    essentially I will be building the pad manually.  Does this sounds like
    a good idea or is there an easier way?
    Thanks again,
    Amer
    Amer wrote:
    Greetings,
    Thank you,
    -- A
    HTH
    -Dave Pollum
    Thanks again,
    Amer
    With 4.16 you can't add copper to a lib part without causing either DRC
    errors or if you use other layers it is unchecked and could cause
    undetected shorts or DRC problems.
    You can add or change the stop mask shape.
    Paul R.
