EAGLE User Chat (English) howto get 'clean' subversion revision info into global eagle properties
  • Subscribers 187 subscribers
  • Views 267 views
There is good news for all eagle users that use subversion to keep
track of there eagle projects and want to put revision information
into there boards and schematics.
I know, that is already possible by inserting subversion keywords into
eagle texts or (global) attributes.
But who wants to see something like "$Revision: 1234 $" on his or her
board?
With the soon to be released Subversion 1.8.0 it will be possible to
get rid of the "$keyword:  $" bracket.
For the following example I will use svn command line tools because
its easier to document, but you can use your prefered GUI client
accordingly.
Let's start then:
In a subversion working copy create a new eagle board file (ckw.brd)
and add a global attribute
     attribute * CKW1 '$ckw1:$'
save the file and
     svn add ckw.brd
the file into version control.
create a text file (cwk.txt) with the following context (don't know if
it is possible without a text file. I didn't really try because of the
quotation marks.)
ckw1="/><attribute%_name="SVN-R"%_value="%r"/><attribute%_name="TAIL1"%_value="
(for the meaning of %_ and %r placeholders see: 'svn help propset')
then set the property
     svn propset svn:keywords -F ckw.txt ckw.brd
and commit the file
     svn commit cwk.brd
looking at the global attributes in ckw.brd now, you will see three
global attributes:
     CKW1     '$ckw1: '
     SVN-R     '12345'
     TAIL1     ' $'
It's a bit of a hack because we manipulate the xml structure, and end
up with two additional attributes.
If you want to add more of the placeholders subversion provides for
use in a custom keyword, be aware that there is a maximal expanded
keyword length off 255 characters.
Lorenz
ckw.7z.zip
