EAGLE User Chat (English) Newbie question on printing PCB in NEGATIVE
  • Subscribers 187 subscribers
  • Views 462 views
I've been using eagle (freeware) for hobby stuff for a few days only. -
I like it !!!
I am trying to print the PCB foil pattern in NEGATIVE.
I figured you can print the PCB out by disabling layers you don't need
then just PRINT and set checkboxes for BLACK, SOLID and optionaly MIRROR
etc. This prints black for tracks,
I need the inverted / negative image.
Does Eagle support this? if so how?
Many Thanks
Anton Schoultz
South Africa
    Anton,
    You'll need to use the CAM processor.
    • Download my postscript cam job
    http://spiffie.org/electronics/archives/tools/Eagle%20Postscript%20Cam%20Job.html
    • In eagle, from the board window, choose File->CAM Processor.
    • In the cam window, choose File->Open->Job...
    • Open the CAM job you just downloaded
    • In each tab, change the device from 'PS' to 'PS Inverted'
    • Click 'Process Job'
    • Close the cam window, save the job
    • In your project directory, you now have postscript files for top,
    bottom, and silk. Use something to print them (Ghostscript, CorelDraw,
    Illustrator, etc.)
    KB
    Anton Schoultz wrote:
    I like it !!!
    Many Thanks
    Anton Schoultz
    South Africa
