EAGLE User Chat (English) Updating Board view after adding component to Schematic view
  • Replies 8 replies
  • Subscribers 177 subscribers
  • Views 943 views
I added a component on my Schematic but couldn't figure out how to refresh
my Board to show the newly added component. How is this done?
Thanks.
    On 2008/Apr/08 2:05 PM, in article ftgc69$gge$1@cheetah.cadsoft.de,
    Hi Frank,
    EAGLE behaves a little differently than other tool flows if you're used to
    having separate schematic and layout editors and with forward and back
    annotating.
    In EAGLE, always edit either file with the other open.  In this case you
    have "constant-annotation".  Anything done in one editor is automatically
    reflected in the other.  Its very handy and reduces lots of consistency
    problems.  However, if you edit one without the other open then you'll
    actually get consistency problems.
    To see if this is what you have done, do an ERC in the schematic (with the
    PCB open as well).  The last line will tell you if you have a consistency
    problem.  If you do, you need to duplicate what you did in the schematic in
    the PCB.  Or go back to an older revision and redo with the PCB open.  It
    depends on the situation as to what is easier.
    If you've done it right, the footprint for the component you added to the
    schematic will automatically appear in the PCB.  It may be off in a corner
    somewhere so you may want to zoom to fit -- it might just be off the visible
    screen.
    I hope that helps.
    James.
    James Morrison
    www.eagletoolkit.com
    EAGLE Design Expert
    North American Online EAGLE Dealer
    EAGLE Enterprise Toolkit
    James,
    It sounds like you are saying that its a manual process....
    For example, if I create a schematic and then the associated board. If I add
    a component to the schematic after creating the board (even though the
    component may be in a corner somewhere), I need to manually create the
    network connections (even though I did so in the schematic already).
    Is that correct?
    "James Morrison" <spam2@stratforddigital.ca> wrote in message
    news:C421335B.16E97%spam2@stratforddigital.ca...
    refresh
    Hi Frank,
    annotating.
    in
    visible
    screen.
    I hope that helps.
    James.
    James Morrison
    EAGLE Design Expert
    FrankP843 wrote:
    James,
    Is that correct?
    Not so, as long as you have the board file open when you add the
    component in the schematic.  THIS IS VERY IMPORTANT !!
    If the above is done, you will see the new component footprint when you
    view the board. This footprint will be off the board, allowing you to
    move it to the position you want. As long as you have the "unrouted"
    layer visible, you will see airwires connecting the new component to the
    correct places on the existing components. You can then either rout
    tracks manually, or ask the autorouter to complete the design for you.
    Whenever you work on a design it is IMPERATIVE to have both the board
    and the schematic open simultaneously. (For a completely new design,
    where you start by drawing the schematic, the board is generated by
    clicking on the board symbol in the top tool bar. It is after that step
    that you MUST have both files open whenever you are doing any editing)
    John G.
    John G.
    Thanks for your feedback, I will make sure to keep both my schematic and
    board views open at all times.
    "John Giddy" <jgiddy@bigpond.net.au> wrote in message
    news:ftk8j0$nk8$1@cheetah.cadsoft.de...
    FrankP843 wrote:
    James,
    add
    Is that correct?
    John G.
    Greetings FrankP843,
      on Fri, 11 Apr 2008 you wrote saying :
    John G.
    And as a helpful hint that you should do this, Eagle will always open
    both if they both exist. So if you open "myProject.sch" and there is a
    "myProject.brd" in the same directory, the board editor will be opened
    automatically (but minimised).
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    John G.
    True.  The catch comes if you then close one of them, because the other
    will stay open, and you can make a change without both being open.
    If you close one file, it is safest to close both so you are not tempted
    to make changes on one file only.
    John G.
    When closing a file, I'd prefer that EAGLE automatically close the
    "other" file, or at least, ask the user if he wants to close the "other"
    file.
    -Dave Pollum
    If you use the control panel to open and close projects (green button)
    then they are both closed or opened.
    Use the exit function to close all of eagle's windows.
    Paul R.
    John G.
    John G.
    file.
    -Dave Pollum
