EAGLE User Chat (English) Draw block diagrams with Eagle?
  • Replies 12 replies
  • Subscribers 179 subscribers
  • Views 3387 views
Hello Folks,
So far I used to draw block diagrams with other (more mechanical) CAD
software but that gets old. Is there a fairly easy way to do that with
Eagle?
It's not about anything being ERC-proof at all, just to illustrate the
function of electronic devices. Boxes, text, lines with arrows at one
end and such.
Regards, Joerg
"gmail" domain blocked because of excessive spam.
Use another domain or send PM.
    On 2008/Apr/14 9:29 PM, in article fu10dd$v6u$1@cheetah.cadsoft.de, "Joerg"
    <notthisjoergsch@removethispacbell.net> wrote:
    Hello Folks,
    Eagle?
    end and such.
    Hi Joerg,
    I usually leave the first sheet of every schematic for just that: a block
    diagram of the PCB.  EAGLE isn't really made for it specifically like say
    Visio.  But then again you don't have to struggle with getting the grid to
    line up like I always have to in Visio.  You can use the wire command (about
    the only thing its good for) to create lines, arrows, rectangles, ....  I
    usually create a few templates at the side off the sheet and then group,
    cut, paste them where I need to.
    For more complex diagrams it might not be worth it since its pretty low
    level.  And not being able to create a group (like a recent suggestion)
    makes it a bit slower.  But its not too bad overall.
    Cheers,
    James.
    James Morrison
    www.eagletoolkit.com
    EAGLE Design Expert
    North American Online EAGLE Dealer
    EAGLE Enterprise Toolkit
    Eagle?
    end and such.
    as soon as you want to connect boxes (containing some text, I guess)
    by "lines with arrows", I suggest to use an specific tool for
    graphs.
    Visio has been mentioned, there are free alternatives as
    http://live.gnome.org/Dia and OpenOffice.org Draw or Inkscape might
    also do the job.
    If you are a text-centric programmer, you might consider AT&T
    http://www.graphviz.org/. It's sometimes more efficient to describe
    the dependencies in a text form and rely on the software to arrange
    the elements than to pull items around with the mouse.
    Oliver
    Hello Folks,
    Eagle?
    end and such.
    Hi Joerg,
    Thanks, James. I use the wire command all the time, didn't know you
    could place arrows with it. So I'll just draw the boxes with "wire" as
    well I guess. Haven't used Visio yet, AFAIK none of my PCs has that.
    OrCad is much better at that and always had a true hierarchy. But I only
    have the DOS version which works via HPGL export and "modern" desktop SW
    can't read that anymore. Heck, maybe I fire up old DOS-Word which
    cooperated perfectly with OrCad SDT and when I am all done I just
    convert it to "modern" MS-Word.
    Regards, Joerg
    Eagle?
    end and such.
    graphs.
    also do the job.
    Yes, those work. They aren't quite as intuitive and simple as CAD
    though. Maybe I fire up the old SDT. Somehow stuff was easier in the DOS
    days. Or maybe I am getting old.
    That one looks really nerdy image
    Regards, Joerg
    also do the job.
    you wouldn't write so if you had used them more then Eagle.
    You get pretty results rather fast.
    Oliver
    autodeskguest over 17 years ago in reply to autodeskguest
    also do the job.
    Oh, I did. For over 10 years. The reason why I stopped was mainly the
    printer support and export utilities. DOS-Word and SDT were a perfect
    team but since clients now want Word-97 compatible files and Microsoft
    broke the old compatibility chain it's not as easy anymore. If MS hadn't
    done that this would have been a no-brainer.
    Eagle is ok but the fact that it cannot do hierarchical designs will be
    the reason for me to abandon it some day.
    True, text based programs are fast but the learning curve for
    non-programmers like me is steep.
    Regards, Joerg
    Joerg wrote:
    Hello Folks,
    Eagle?
    end and such.
    Hi Joerg,
    We have done many mechanical design drawings with Eagle.
    When we have a project that requires schematics, PCB, system wiring
    diagrams and mechanical drawings for machining assemblies and panels,
    we do it all with eagle.  just don't have the time to learn several
    programs for one project.
    Mechanicals are easy.  We have a Template Sheet that is part of every
    project requiring any mechanical drawings.  The template has various
    Arrows (for pointing and dimensions), Line Stiles, Valves, Screws,
    Springs, and other oddball stuff not found in the usual PCB project.
    The new 5.0 makes this even easier because of the thumbnails and sheet
    reshuffling.  We just copy the needed part to the worksheet.
    We even have Symbol sheets of CNC Ladder, Pneumatic/Hydraulic and
    Software Flow Chart stuff.
    We build all of this stuff with WIRES so they are easy to Resize to
    fit the application at hand.  Even Circles and Arcs will resize in 5.0
    Best of all, we only create the component once for all time use.
    This all may have been a bore, or maybe useful.
    Brownie
    Brownie wrote:
    Joerg wrote:
    Hello Folks,
    Eagle?
    end and such.
    Hi Joerg,
    Not boring at all, this is interesting. I'll have to look at how
    templates are done, so far I have only created library parts. The manual
    doesn't mention templates. But even with a library it could be done,
    except that you can't resize parts easily which I'll have to do at least
    with the boxes. But those can be sketched directly with the wire command.
    Thanks, Brownie.
    Regards, Joerg
    Joerg wrote:
    Brownie wrote:
    Joerg wrote:
    Hello Folks,
    Eagle?
    end and such.
    Hi Joerg,
    Thanks, Brownie.
    Joerg,
    We refer to our component sheets internally as templates but the
    manual nay not mention this.  Our Templates are nothing more than a
    schematic sheet with the various components drawn in.
    An Eagle Library (maybe call it Special_symbols.lib) could be used,
    BUT our applications often require resizing of the symbols and I don't
    think this is possible with library parts.
    Our Template Sheets are defined in our Skeleton Eaglerc and .EPF files
    so that they will auto-load with all new projects.  The sheets can be
    deleted when the project is done.
    Brownie
    Brownie wrote:
    Joerg wrote:
    Brownie wrote:
    Joerg wrote:
    Hello Folks,
    Eagle?
    end and such.
    Hi Joerg,
    Thanks, Brownie.
    Joerg,
    Aha. So you are basically drawing a sample schematic which gets dragged
    along as a sheet, parts are picked from there and then deleted at the
    end. Pretty clever.
    And yes, I believe that's the only way to keep things resizeable because
    the library editor in Eagle is IMHO, ahem, a bit on the clumsy side.
    Regards, Joerg
