EAGLE User Chat (English) Identify ghost pad
  • Subscribers 178 subscribers
  • Views 469 views
Identify ghost pad
Former Member over 17 years ago
I've drawn up a library for a new part. When I connect the symbol to the
package I see a supplementary pad to be connected. I can not see it in
that package drawing, but like to eliminate the part.
Supposedly I can identify something in the drawing with the show
command. Unfortunately the precise syntax seems convoluted enough as I
seems unable to even show stuff I can see and click on.
for example: show 'smd: 8' should highlight pad 8, but I get a popup
with 'smd: 8, not found'.
Markus
    Markus
    One thought:  Is it possibly on a different layer ?
    John G.
    John G.
    I didn't thought about layers. What if I want to search across all
    layers ? After all, I know the objet name !
    Markus
    eagle names pads like P$2 if you don't override that manually.
    So 'show P$8' may do what you want.
    Lorenz
    "Markus Baertschi" <markus@markus.org> schrieb im Newsbeitrag
    news:fueun4$tp8$1@cheetah.cadsoft.de...
    John G.
    I didn't thought about layers. What if I want to search across all layers
    Markus
    DISPLAY ALL
    T.
    I think I've found what happened. I can not be sure because in the end I
    scrapped the stuff and started from scratch.
    However, the pins were called '1', '2', etc. The string 'smd: in front
    was not part of the name but part of eagles's prompt in the status line.
    Markus
