EAGLE User Chat (English) Gerber files - mirror option
  • Replies 7 replies
  • Views 2524 views
e14 Contributor over 18 years ago
When I use the default gerb274x cam processor for the solder side
layers the 'Mirror' option is set. This makes verifying the produced
gerbers difficult as the layers don't sit correctly on each other.
Is this required by board-houses ?
If I switch Mirror off for verification and forget to re-run the
cam processor with Mirroring on will I get a non-functional board ?
Markus
    John Giddy wrote:
    With Olimex you can just send the *.brd file and they do the
    post-processing.
    Has worked well for me over several different two-layer boards.
    John G.
    I know, but Olimex has a quite hing limit on drill and copper size. I'm
    looking into one board where I'd need smaller features and Olimex would
    not work out. If I'm at it, lets learn !
    Markus
    Markus Baertschi wrote:
    T.Strothmann wrote:
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> schrieb im Newsbeitrag
    This is more of a legacy default and I have unchecked the mirror on
    my cam files I use.
    Paul R.
    Yes. Did the same. No problems checking the gerber plots using
    "GCPREVUE", no problems no matter the board house I dealt with.
    T.
    Thanks Gentlemen,
    that's the info I was looking for. I'll happily uncheck the mirror
    option and save is as default.
    I was following the instructions given by Olimex. They are quite
    specific for many things, but this was not mentioned at all.
    Regards   Markus
    post-processing.
    John G.
    This is more of a legacy default and I have unchecked the mirror on my cam
    files I use.
    Paul R.
    Yes. Did the same. No problems checking the gerber plots using "GCPREVUE",
    T.
    Thanks Gentlemen,
    Regards   Markus
    news:fuitr2$kiu$1@cheetah.cadsoft.de...
    T.Strothmann wrote:
    Never had any problems with unmodified (non-mirrored) data. Many years
    ago I used to mirror the bottom layer, no problems either. In theory you
    should be able to send out anything you want as long as you describe all
    details of the chosen format to the boardhouse, and as long as they
    accept it. But maybe it reduces the likelihood of mistakes somewhat, if
    you stick to an "all layers in the same format" scheme.
    T.
    I can see your point. But the gerb274x.cam file by default does mirror
    the bottom layers. At the same time board houses say you should carefully
    examine the gerbers, which seems somewhat contradictory as you can not
    verify your gerbers if half of them are the wrong way round.
    Way back when eagle was started you would be using film and need the
    emulsion next to the PCB photo resist layer. So it needed to be printed
    mirrored. Most of the time the Gerbers (HPGL possibly) went from the disk
    to the photo/pen plotter without having (much of) a computer available to
    mirror the layer.
    I did not see any remarks about this in any of the tutorials and am just
    wondering if there is a consensus about thet.
    Markus
    files I use.
    Paul R.
    T.
    you should be able to send out anything you want as long as you
    describe all details of the chosen format to the boardhouse, and as
    long as they accept it. But maybe it reduces the likelihood of
    mistakes somewhat, if you stick to an "all layers in the same format"
    scheme.
    T.
    carefully examine the gerbers, which seems somewhat contradictory as you
    can not verify your gerbers if half of them are the wrong way round.
    disk to the photo/pen plotter without having (much of) a computer
    available to mirror the layer.
    Markus
    cam files I use.
    Paul R.
    T.Strothmann wrote:
    Never had any problems with unmodified (non-mirrored) data. Many years ago I
    used to mirror the bottom layer, no problems either. In theory you should be
    able to send out anything you want as long as you describe all details of
    the chosen format to the boardhouse, and as long as they accept it. But
    maybe it reduces the likelihood of mistakes somewhat, if you stick to an
    T.
    Markus
    "Markus Baertschi" <markus@markus.org> schrieb im Newsbeitrag
    news:fuf9t9$jci$1@cheetah.cadsoft.de...
    Markus
    T.
