EAGLE User Chat (English) How to delete mysterious zero-width wire?
  • Subscribers 177 subscribers
  • Views 441 views
Hi!
I'm fairly new to Eagle.
I seem to have introduced a 2-mil, zero-width wire into my board layout.
  I can't select it in any way, so I can't get any info. about it, and I
CAN'T DELETE IT.
I thought it might just be an artefact of the rendering process, but
alas it is really there becacause Eagle is leaving a nice gap around it
when I poly-fill the area around it.
I assume as a last resort there is some text-format file I can inspect
and edit?
Is there a guru out there who can throw me a lifeline?  image
//Mike
    On 2008/Apr/29 2:44 PM, in article fv7q9n$q5c$1@cheetah.cadsoft.de, "Mikey"
    <mik@lamming.com> wrote:
    Hi!
    CAN'T DELETE IT.
    and edit?
    Hi Mike,
    This could be a couple of things.  One thing that often throws people is
    that DRC errors sometimes look like copper.  So you can either close and
    open the file to get rid of it or use the GUI to delete the errors.
    If it is really copper than figure out what layer it is on and turn off all
    the other layers.  Then group it all together and delete the group.  That
    should do it.
    Cheers,
    James.
    James Morrison
    http://www.eagletoolkit.com
    Online EAGLE Dealer for US and Canada
    EAGLE Design Expert
    EAGLE Enterprise Toolkit
    Hi!
    CAN'T DELETE IT.
    and edit?
    Hi Mike,
    should do it.
    Cheers,
    James.
    James,
         Thanks for the suggestion, but no joy!
    Firstly - the "zero-width line" (zwl) really does seem to be copper on
    the bottom layer.
    If I show just the offending layer and try to select the zwl (e.g. using
    the GROUP tool) Eagle complains that it can't "back annotate", and that
    I should do this on the schematic.
    But I can't figure out WHERE IT IS on the schematic.  If I select it on
    the layout, it isn't automatically highlighted on the schematic.
    Because I'm new to this I'm probably missing something really obvious.
    //Mike
    On 2008/Apr/29 6:29 PM, in article fv87gm$mvo$1@cheetah.cadsoft.de, "Mikey"
    Hi!
    CAN'T DELETE IT.
    and edit?
    Hi Mike,
    should do it.
    Cheers,
    James.
    James,
    the bottom layer.
    That means you are trying to delete a component.  Are the origin (top and
    bottom) layers off?  If not, turn them off too.
    One of two things could be happening:
    1)  The origin layer is on and when you select the artefact you are also
    selecting components and the delete group doesn't like deleting the
    components.
    2)  The artefact is actually part of a footprint.  In that case you'd have
    to change the library package and remove the artefact there, then update the
    design with the modified library.
    Those would be my guesses.
    Good luck.
    James.
    James Morrison
    EAGLE Design Expert
    Hi!
    CAN'T DELETE IT.
    and edit?
    Hi Mike,
    should do it.
    Cheers,
    James.
    James,
    the bottom layer.
    components.
    Good luck.
    James.
    James
         It was #2.   Thanks for the clairvoyance!
    //Mike
