EAGLE User Chat (English) make_bga.ulp - was (long ago) Re: importing a BMP
  • Views 548 views
amigabill
amigabill over 13 years ago
Hi all, I'm getting the same kind of permission error as the guy from
this old thread about importing a BMP:
http://www.eaglecentral.ca/forums/index.php/m/149085/b7a7f12f912cdd48ce7fe51e23f05511/?srch=ulp+permission#msg_149085
Can't open C:\Program Files(x86)\EAGLE-5.12.0\bga256_package.scr
(using the default GUI values that make_bga.ulp fills in for me, no changes)
I'm not sure what to do. I removed all $EAGLEDIR things in my directory
options, so I don't expect it to be looking there for anything.
As the solution for the thread I linked to suggests, I've made it so
there should only be directories for libs, projects, ulps, scripts, etc.
in the place where I am able to make edits. But It's still trying to go
into the root Eagle install dir for the script file it wants to write out.
I am using Eagle 5.12.0 Pro, trying to make a library package using this
BGA ulp, using Windows 7 Ultimate 64bit.
The directory location of my library is:
F:\documents\billt\projects\eagle\my_libraries\error_demo.lbr
The contents of my directory options window is:
Libraries:
F:\documents\billt\projects\eagle\my_libraries;F:\documents\billt\projects\eagle\others_libraries
Design Rules: F:\documents\billt\projects\eagle\DesignRules
User Language Programs: F:\documents\billt\projects\eagle\ulps
Scripts: F:\documents\billt\projects\eagle\scripts
CAM Jobs: F:\documents\billt\projects\eagle\CAMjobs
Projects:
F:\documents\billt\projects\eagle\my_projects;F:\documents\billt\projects\eagle\others_projects
So, with all the C:\... tool install dir stuff removed already, how do I
get through this?
I run this by starting Eagle and opening my library, which I have
written a small description for, and do have a bga256 package name
defined and saved, but is empty on the footprint layout screen. I've
tried this from the empty bga256 footprint screen, as well as fromt eh
library screen without opening any packages/symbols/devices. Same error
either way.
(P.S. I do plan to upgrade to Eagle 6.x Pro when my finances give me a
break, but someone I am collaborating with on some of this design has
5.x and last I heard no plans for 6.x. so I'm sortof stuck with 5 anyway)
I really do appreciate some help with this. I intend to meddle with a
very large 43x43 BGA (reference design is 20 layers, I hope to reduce
that to at least no more than Eagle 5's 16 max. Does 6 go above 16 now?)
Bill Toner
amigabill at that gee mail place
  • amigabill
    amigabill over 12 years ago in reply to autodeskguest
    On 7/28/2013 3:22 AM, Warren Brayshaw wrote:
    Hi Bill
    make_BGA.ulp is a bit old (2004) and so does not cater well for large BGAs.
    The ULP is taking rows from the ASCII table so an array  over about 20x20
    goes all wrong and shoots past the end of capital letters, does some
    punctuation and then starts on lowercase letters. so eventually you get an
    'a1' which matches your already created 'A1'
    Try another ULP;  make-symbol-device-package-bsdl.ulp (by the same author).
    It seems it can take an input file to create/ match signal names to balls.
    That would save a lot of work connecting pins to pads.
    All the best
    Warren
    Hi Warren,
    Thank you, this works much better! I need to look into the other ulp
    about splitting symbols as well, to see if that will help make this
    giant sea of pins symbol into something more manageable. Trying to
    figure out the best way to get things to look like my reference design
    symbols they provided.
    Bill
    autodeskguest over 13 years ago in reply to amigabill
    William Toner wrote:
    On 7/28/2013 12:15 AM, William Toner wrote:
    from this old thread about importing a BMP:
    changes)
    directory options, so I don't expect it to be looking there for
    anything.
    etc. in the place where I am able to make edits. But It's still
    trying to go into the root Eagle install dir for the script file it
    wants to write out.
    this BGA ulp, using Windows 7 Ultimate 64bit.
    Libraries:
    Projects:
    gle\others_projects
    do I get through this?
    eh library screen without opening any packages/symbols/devices.
    Same error either way.
    me a break, but someone I am collaborating with on some of this
    design has
    anyway)
    a very large 43x43 BGA (reference design is 20 layers, I hope to
    reduce that to at least no more than Eagle 5's 16 max. Does 6 go
    above 16 now?)
    Bill Toner
    OK, I spent some time in help and hacked up what I think is an
    improvement to the original make_bga.ulp script:
         /* package_file = package_name + "_package.scr"; */
         package_file = path_scr[0] + '/' + package_name +
    "_package.scr";
    Do path/filenames by default start at the eagle tool install dir? Is
    there a better way to output elsewhere?
    Bill Toner
    Eh, while this corrected the error abotu writing out the script file,
    it does not yet get me my giant BGA footprint. I get errors that Pad
    Name A1, A2, A3 etc. already exist. I'm guessing this happens instead
    of stepping to AA1, AA2 etc., then AB1, AB2, etc... :/ More hacking
    to go...
    Bill Toner
    Hi Bill
    All the best
    Warren
    news.cadsoft.de
  • amigabill
    changes)
    out.
    Libraries:
    Projects:
    get through this?
    either way.
    Bill Toner
         package_file = path_scr[0] + '/' + package_name + "_package.scr";
    Bill Toner
    Eh, while this corrected the error abotu writing out the script file, it
    does not yet get me my giant BGA footprint. I get errors that Pad Name
    A1, A2, A3 etc. already exist. I'm guessing this happens instead of
    stepping to AA1, AA2 etc., then AB1, AB2, etc... :/ More hacking to go...
    Bill Toner
  • amigabill
    changes)
    Libraries:
    Projects:
    get through this?
    either way.
    Bill Toner
    Bill Toner
