EAGLE User Chat (English) Draw a parabolic shaped wire in Eagle
  • Subscribers 178 subscribers
  • Views 366 views
Would anyone like to share a ULP that draws a wire shaped by a polar
function.
For example R=(2*L)\(1+cos(Theta))
L=(n*lambda)\4
Theta= angle from x axis
R= length of the vector
  • WestfW
    WestfW over 17 years ago
    function.
    L=(n*lambda)\4
    /* parabolic.ulp
    • The key thing to remember seems to be that the ULP trig
    • functions all work on arguments in radians, while the
    • polar coordinates you use when specifying points to the
    • wire command are in degrees.
    • watch out for cos(t) = -1 (divide by 0) at theta = 180 !
    /* User parameters to be changed */
    real lambda = 20.0;
    real n = 4;
    real theta_start = -100.0, theta_end = 100.0 ;
    real delta_theta = 10.0;
    /* Actual code starts here */
    string h, cmd ="";
    real theta;
    /* convert degress to radians for trig math. */
    real d2r(real deg)
         return(deg * PI)/180.0;
    /* main */
    sprintf(h, "grid mm; mark (0 0);\n set wire_bend 2; wire "); cmd +=h;
    real L = n * lambda/4;
    for (theta = theta_start; theta <= theta_end; theta += delta_theta) {
         real r = (2.0*L)/(1.00+cos(d2r(theta))); // Calculate R
         sprintf(h, " (P %f %f)", r, theta);  // add next point to wire.
         cmd += h;
    cmd += ";";
    exit(cmd);
