EAGLE User Chat (English) Change Eagle directories to %USERPROFILE%
  • Views 648 views
JasonTraud
JasonTraud over 13 years ago
Whenever I try to change the target directory to the user folder like it should be, Eagle creates a folder called %USERPROFILE% in root C. Is there a simple workaround to force Eagle to accept the environment variable? I would prefer not to hard link it directly to my folder.
  • JasonTraud
    Since I found a solution myself, I figure I should share. Eagle does not allow the use of environment variables such as userprofiles or home but allows the keyword $home to point to your "My Documents" directory.
    Why it saves your data by default in the Programs directory is anyone's guess.
